Tile To Carpet Transition - Flooring - DIY Chatroom Home Improvement Forum
Old 03-17-2013, 10:24 PM   #1
Rewards Points: 640
Tile to carpet transition
I am tiling half a floor then having carpet on another half... I need a good transition edge between the tile and carpet..
The carpet is not commercial carpet, but standard residential carpet
I was looking at putting something like a Schluter Systems tile edge, or something similar to get a flush edge...
Do they have any carpet to tile transitions? or do you just use a flat edge tile edge trim? I am trying to stay away from big wood caps or marble thresholds... This will be a 24 ft long edge.
Any suggestions? Thanks!
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
BlueBSH is offline   Reply With Quote
Old 03-17-2013, 11:16 PM   #2
Floor Installer
sam floor's Avatar
Rewards Points: 154
There is a rubber cap transition.
sam floor is offline   Reply With Quote
Old 03-18-2013, 07:37 AM   #3
Rewards Points: 640
not sure I'd like a rubber one either... any examples out there (or brand names) to get an idea of what it looks like?
Old 03-18-2013, 07:42 AM   #4
Floor Installer
sam floor's Avatar
Rewards Points: 154
First picture I could find.
Old 03-20-2013, 02:40 PM   #5
transition
I would use z-bar and have the carpet tucked to the tile. Make sure the tile is well set and grouted before installing the carpet. If its vct tile then use any standard naplock.
sirdonofca is offline   Reply With Quote
Old 03-21-2013, 01:26 PM   #6
Rewards Points: 744
http://www.schluter.com/137.aspx
These may help you as well. They go under the carpet pad. http://www.carpetshims.com/choosing_...ght_shims.html I used them after tiling my bathroom. Along with the Schluter-SHIENE, you'll have a perfect transition.
Seattle2k is offline   Reply With Quote
carpet to tile transition... longshanks Flooring 1 02-11-2011 05:09 PM
Tile, hardwood, and carpet questions ws450r Flooring 1 07-02-2010 02:40 PM
ceramic tile transition to laminate Kman92592 General DIY Discussions 1 07-01-2010 10:55 PM
Transition from grouted vinyl tile to carpet MI-Roger Flooring 2 11-29-2009 01:55 PM
Joining carpet and ceramic tile rooms TedT Flooring 10 05-21-2008 09:25 PM
