Tile/carpet Threshold Bad Job Can It Be Fixed? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-16-2010, 08:16 PM   #1
Unhappy
tile/carpet threshold bad job can it be fixed?
Hi,
I'm new here and really need some advice. We have a contractor working on our bathroom and so far he has done an okay job. One thing I'm really not happy with is the threshold between the carpet and tile. Hopefully a picture will explain it better. I keep thinking my little children are going to trip and fall. Is there anything I can suggest for him to fix/change it.
tile/carpet threshold bad job can it be fixed?-floor.jpg   tile/carpet threshold bad job can it be fixed?-floor-2.jpg   tile/carpet threshold bad job can it be fixed?-floor-3.jpg
cathy244 is offline   Reply With Quote
Old 06-16-2010, 08:44 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 128
Did he install carpet, tile, both?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 06-16-2010, 08:59 PM   #3
Hi, He didn't do the carpet, just the tile.
Old 06-16-2010, 09:37 PM   #4
firehawkmph's Avatar
Rewards Points: 1,884
Cathy,
can't quite tell by the pics, but is the metal strip showing going under the tile, and if so, is the tile sticking up above the top of the strip? I like to use some sort of threshold in between the tile and carpet in a doorway situation like yours. The metal trim pieces the tile companies carry come in different sizes. The top of the strip should end up flush with the top of the tile. Something doesn't look quite right in your pics.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 06-16-2010, 09:48 PM   #5
DIY staff
Rewards Points: 7,174
Cathy,A wood reducer could be made that could cover the edge of the tile and eliminate the need for the metal carpet bar.
The door cuts are not perfect enough for a wood reducer to be flush with the tile itself.
Most installers try for perfection on the 'Show' cuts. --Mike--
Adhesive for Marble Threshold Twister Flooring 11 05-14-2011 01:20 PM
Threshold at the front door and Tile abedj Carpentry 4 08-28-2010 03:36 PM
Threshold prep and paint? Guido Painting 4 09-11-2008 10:08 AM
New Door with Wood Threshold Over Limestone BigJimmy Building & Construction 1 02-08-2008 05:36 AM
Threshold problem from bedroom to patio Not Sure Carpentry 11 11-07-2006 07:16 PM
