Tile--Carpet Strip Missing - Flooring - DIY Chatroom Home Improvement Forum
Old 07-13-2008, 03:43 PM   #1
Tile--Carpet strip missing
I moved into this house not long ago and noticed the builder never put anything between the tile and carpet. It's annoying at times when somebody steps on a staple. I was at the store the other day looking at reducers and it appears it is designed to slide under the tile to hold it in place. Is there an easy way to get it under the existing tile without messing the tile? Any suggestions are appreciated.
Super33 is offline   Reply With Quote
Old 07-13-2008, 04:05 PM   #2
Rewards Points: 2,906
Super33:
Install track base. Look at the MT-00-B track base on this web site:
http://www.johnsonite.com/NR/rdonlyr...base_chart.jpg
It has a flange on one side that gets nailed to the floor under the carpet. That flange has pins on it to grip the carpet.
The other side of the track base butts up against the edge of the tiling.
That side has a groove in it so that you can press in a "T Molding" like these:
http://www.johnsonite.com/NR/rdonlyr...ings_chart.jpg
There are different kinds of T Moldings for different heights of flooring on each side of the track base. And, those T Moldings come in 48 different colours, but most places will only stock brown and black in each kind.
Nestor_Kelebay is offline   Reply With Quote
Old 07-13-2008, 05:43 PM   #3
Hey, that looks like exactly what I'm looking for, Thanks very much for the fast reply and the help nestor
Old 07-13-2008, 06:04 PM   #4
No problem.
That'll be 35 cents.
Please contact the forum moderator to arrange payment.
Carpet and slate tile on same basement floor CBH Flooring 14 06-12-2008 03:14 PM
Joining carpet and ceramic tile rooms TedT Flooring 10 05-21-2008 08:25 PM
Underlayment height for tile / carpet.... scheenstra Flooring 2 04-23-2008 12:12 AM
Help! Ceramic Tile to Carpet Transitions. sunangel Flooring 3 12-11-2007 02:19 PM
