From Tile To Carpet - Flooring - DIY Chatroom Home Improvement Forum
Old 05-14-2010, 09:32 AM   #1
From tile to carpet
We are doing something that most people apparently don't. We pulled up tile to put down carpet. There is mortar on the floor underneath the tile. We purchased a heavy duty scraper, and it doesn't really even do anything to remove the mortar. My question is under a 6 lb pad, and plush carpet, will you be able to feel the mortar bed under there if we don't scrape it down?
cherylanne is offline   Reply With Quote
Old 05-14-2010, 04:42 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
YES! Over time the irregularities will telegraph thru the pad/cushion.
XXX
Old 05-14-2010, 05:44 PM   #3
What is the mortar on top of? I would say that at least sand down the high spots and make it all rounded type of mortar bed. You should try and get up as much mortar as possible.
natcotroy is offline   Reply With Quote
Old 05-14-2010, 08:04 PM   #4
you cold skim the floor
The older I get the better I was
Old 05-15-2010, 08:52 AM   #5
An old Tradesmen
Rewards Points: 6,846
Flooring.
If you wish to advertise here. You can purchase advertising.
Links to websites are permitted, if you post actual DIY help to people asking how to do something.
Old 05-15-2010, 10:41 AM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
"Skim-coating" is a possibility but the truth of that process is that you may end up with a situation worse than you started with in some cases. It's not always easy for a novice with a trowel to successfully skim-coat a rough surface and not have the trowel hopping around over every high spot.
XXX
Old 05-15-2010, 10:50 AM   #7
this be a truism
Transition from grouted vinyl tile to carpet MI-Roger Flooring 2 11-29-2009 12:55 PM
Curved tile to carpet transition toocheaptohire Flooring 5 04-16-2009 02:37 PM
Tile baseboard with carpet? bpak04 Flooring 2 11-03-2008 12:28 PM
Joining carpet and ceramic tile rooms TedT Flooring 10 05-21-2008 08:25 PM
Underlayment height for tile / carpet.... scheenstra Flooring 2 04-23-2008 12:12 AM
