Tile Baseboards - Flooring - DIY Chatroom Home Improvement Forum
Old 08-02-2010, 01:53 PM   #1
Rewards Points: 184
Tile baseboards
When doing a tile floor is it pretty common to use tile for the baseboards? Or is wood common as well?
If doing tile do you go 4"? Beveled edge or regular? How does the tile stick to the wall? Is the tile cement enough to hold it? Do I put those in before I grout the rest of the floor? Or do the floor first then the baseboards?
TIA
abefroman is offline   Reply With Quote
Old 08-02-2010, 03:06 PM   #2
Handyman
Rewards Points: 512
TIA
I have done lots of tile baseboards but usually for commercial use. Depending on the room size, yes, 3-1/2 to 4" is a good size. You can use the bullnose tile if you have it or just make sure you put the cut end of the tile towards the floor leaving the factory edge towards the wall. The thinset you're using for the floor will work just fine.
Not only do you want the baseboard in before you grout but you will want to paint the wall (at least to the baseboard height) to make painting easier...cutting in around grout is a pain in the
To finish the top of the b.b. you can either grout it or find a matching caulking (run a line of painters tape across the top for a nice neat job)
canadaclub is offline   Reply With Quote
Old 08-03-2010, 04:29 PM   #3
57_Hemi's Avatar
For the top of the baseboard I ALWAYS choose caulking over grout....... Grout will most likely crack over time due to any shifting or movement of walls, floors etc etc.
As canadaclub mentioned..... painters tape across the top with whatever u decide to use (grout, caulking) will give it a very nice and straight clean apperance........ than agiain thats only if you tape it straight....lol
57_Hemi is offline   Reply With Quote
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 10:07 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
