Tile Baseboard On Drywall Or Backer Board - Flooring - DIY Chatroom Home Improvement Forum
Old 05-20-2011, 04:44 PM   #1
Rewards Points: 1,062
Question
tile baseboard on drywall or backer board
if i am just making a 6" tile baseboard, will it be OK if i just set them on drywall or should it still be backer board?
Old 05-20-2011, 05:52 PM   #2
NACE Coating Inspector
mustangmike3789's Avatar
is this in a wet area? it is ok to set tiles over dry wall. i prefer backer board because it will not rot or become damaged from moisture.
mustangmike3789 is offline   Reply With Quote
Old 05-20-2011, 06:02 PM   #3
it is in a powder room. just a toiler and a lavatory.
Old 05-20-2011, 06:19 PM   #4
dry wall ill be fine. i prefer to use thiset vs. mastic when i set tiles. it will hold up longer and moisture doesn't affect it
The Following User Says Thank You to mustangmike3789 For This Useful Post:
amakarevic (05-20-2011)
Old 05-20-2011, 06:27 PM   #5
why would anyone ever wanna use mastic vs. thinset?
Old 05-20-2011, 06:41 PM   #6
home depot tells them to. no mixing. longer pot life. close the bucket and use it next weekend.
Old 05-20-2011, 06:43 PM   #7
those who listen to advice from HD incompetent douchebags deserves to have their project fail in an epic way...
Old 05-20-2011, 06:48 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I would use mastic for this application. It comes in smaller quantities and will work just fine in this case. No muss no fuss!
XXX
Old 05-20-2011, 06:52 PM   #9
but how hard is it to mix some thinset from a bag in a paint bucket with a blender-like attachment to a regular drill (one of my favorite recent tool discoveries that saves a lot of time and effort mixing small amounts) or even doing it manually in a tub?
Old 05-20-2011, 06:56 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Oh now you want to argue?
What the hell would you do with the remaining 47 pounds of thinset that will be left over. Why would you also want to clean the bucket and the mixer if it isn't necessary?
XXX
Old 05-20-2011, 07:00 PM   #11
i dont blame you one bit. my preference is always thinset even on a dry backsplash. maybe im a little "old school". dont get me wrong, i like the ease of use on a lot of the new products but in my own house i still like mud jobs,thinset and pack mud w/wet setting the tiles on my shower floors. the OP question was "why would anyone choose mastic over thinset?" at any point i would assume.
Old 05-20-2011, 07:03 PM   #12
i always keep buckets with lids of things like mortar mix, thinset, and grout, just like you would have jars of flour or sugar in the kitchen.
yes, cleaning is a little messy but i have a streamlined system for that as well.
Tile over Particle Board dgun357 Tiling, ceramics, marble 2 01-16-2010 09:00 PM
Replacing drywall without removing tile through an interior wall MLP Drywall & Plaster 6 08-06-2009 12:35 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
How Do I Patch Tile Backer Board? rajrae Tiling, ceramics, marble 1 11-17-2008 10:43 PM
tile backer board yudamann Flooring 1 06-29-2006 08:53 PM
