Tile Baseboard - Flooring - DIY Chatroom Home Improvement Forum
Old 07-05-2007, 02:39 PM   #1
Tile Baseboard
I will begin laying ceramic tile in my basement bathroom in the next week (when the drywaller is done). I am planning to use ceramic tile as the baseboard as well, and was wondering the best way to do it. How should it line up with the floor tile? How much of a gap between the floor tile and baseboard tile (can I set the baseboard right on the floor tile)? Do I need to use caulk between them? Any other tips or pictures would be greatly appreciated.
leted_82 is offline   Reply With Quote
Old 07-05-2007, 02:48 PM   #2
just make sure you measure your door trim correctly when you laying tiles around door...you suppose to lay door trim first before laying baseboard... but you can do it the other way around if you do good measurement and don't come across to big or too small gap situation.
for caulking or not... I think caulking is a good idea to give additional water protection... but then you may not like the look and decide to go without caulking... either way it is not that big a deal...
KUIPORNG is offline   Reply With Quote
Old 07-07-2007, 06:41 AM   #3
Tile and Paint contractor
Set the baseboard tile on top of floor tile and push flush to wall following grout lines of the floor. After grouting, use a siliconized caulk that matches the color of the grout used on the transition between wall and floor.
Matt | tile contractor
Charlotte, NC
MattCoops is offline   Reply With Quote
Old 07-07-2007, 11:57 AM   #4
I recommend setting the base off the floor by 1/16", then caulking.
Rich
Remodeling is offline   Reply With Quote
Tile vs Wood as a baseboard MattCoops Flooring 14 11-12-2014 03:26 PM
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
Cutting exiting baseboard flush with tile mowedthelawn Carpentry 21 06-24-2007 11:53 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
