#1 |
tile backer board
I would appreciate a user opinion on using Georgia-Pacific DensShield tile backer in place of conventional cement board. It's lighter, easier to handle and cut and has a no nonsense warranty. Is this too good to be true?
#2 |
tile backer board
I would only use it for tub surrounds and shower walls over prefab pans, don't use it for walls in mud pans.
![]() I also install a vapor barrier in the corners 4" out to protect the studs there in the event moisture gets through the thinset and caulk and make sure you leave a 1/4" gap above the pan or tub and caulk this joint well after tiling.
| Display Modes | |
| calking backer board to tub | glassman | General Discussion | 13 | 06-19-2008 09:41 PM |
| Preping for ceramic tile install | leroyme | Flooring | 21 | 11-29-2007 04:31 PM |
| Backer board vs. plywood for tile underlayment | allpraisebob | Flooring | 4 | 01-07-2007 08:44 PM |
| Tile and laminate, or get rid of tile? | kfoster | Flooring | 10 | 03-17-2006 03:14 PM |
