Old 02-19-2011, 11:48 AM   #1
User
Tile after new subfloor
Repairing my bath subfloor after extensive dry rot. We have decided to install tile when the floor is done.
I've read lot's of different opinions here and would like to narrow it down for my application.
There was 1 1/8" T&G with a 3/8" fiberboard underlay then carpet.
I replaced the 1 1/8" T&G with new T&G same size. ( 48" span floor)
What should I use for underlayment for the tile? Do I put wood underlayment then backer board or just backer board, the thinset and tile. What about a vapor barrier for the floor (73 ranch style with crawl)
Subcooled is offline   Reply With Quote
Old 02-19-2011, 12:54 PM   #2
Tileguy
Bud Cline's Avatar
All that is required now is a suitable tilebacker product. Understand that all tilebackers are to be installed in a fresh bed of thinset mortar and then immediately fastened to the substrate. The thinst bed is most important.
Old 02-19-2011, 01:48 PM   #3
Tileguy
JazMan's Avatar
I wanted to add that we are assuming the 1 1/8" t&g is subfloor grade plywood and not planks. If you had the room it wouldn't hurt to add more ply, probably will be OK without it as long as the tiles are not natural stone.
Also note that although we know people with that type of framing have had good luck with tile installation, you will not find a spec when the joists spacing is over 24". You're on the left coast right?
As far as vapor barriers because of the crawl space, we can only recommend you do what is suggested for your area.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 02-19-2011, 01:55 PM   #4
Tileguy
Bud Cline's Avatar
Jaz,
I bow to your keen perception. Two good "catches" there.
( 48" span floor)
I missed that entirely. This may call for extra measures.
...assuming the 1 1/8" t&g is subfloor grade plywood and not planks.
Another good catch. If the subfloor is planks then plywood would be required.
Old 02-19-2011, 05:38 PM   #5
Tileguy
JazMan's Avatar
Thanks Bud, sometimes our eyes get a bit blurry.
OK, you're on your own starting tomorrow. I'm away for a few days.
Jaz
Old 02-19-2011, 09:41 PM   #6
Tileguy
Bud Cline's Avatar
Enjoy!
Old 02-20-2011, 01:58 AM   #7
User
Thanks for the replies. I did forget to mention that the old was 48" span but no longer as I installed 16 OC and 2 x 6 flat where the tile shower will go and various other locations . Now have lot's of support.
the new floor is 1 1/8" t&g subfloor grade plywood.
Old 02-20-2011, 02:00 AM   #8
User
Bud, what is your preference brand for tilebacker product?
Old 02-20-2011, 11:57 AM   #9
Tileguy
Bud Cline's Avatar
I've used them all over the years of course.
Of the traditional grey colored cement boards I always preferred Permabase. Permabase always seemed to me to have superior quality control in their finished product and the tapered edges were always consistent in shape and size.
I also have used a lot of Hardibacker and actually prefer it over the Permabase, again because of edge consistency.
Then a few years ago along came the Green-E board which is what I have progressed to. Green-E is lighter weight than the others and it truly does cut as easy as drywall. It is white in color but green in construction. And...according to the maker you can staple it (using the correct staples and air adjustments) to the substrate.
Those are boards. The absolute best tile underlayment to ever come down the pike is Schluter's DITRA. When I can cover the cost DITRA is my choice hands down.
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 48 05-14-2013 10:43 PM
laying stamped concrete over old tile Kimmarie Flooring 24 03-20-2012 01:20 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Help with tile on subfloor please ddmnkf Tiling, ceramics, marble 11 09-26-2009 07:21 PM
Replacing Subfloor whatispunk Flooring 1 09-01-2009 10:50 PM
