Old 05-05-2012, 07:12 AM   #1
Tile adhesive
I'm going to install some slate tile on a concrete floor. My first experience with this. Should I use thinset or adhesive to put it down? The floor is flat but was painted years ago. How should I prep it? Does the paint have to come off?
Gary
Gary Sutherland is offline   Reply With Quote
Old 05-05-2012, 11:36 PM   #2
Tileguy
JazMan's Avatar
Tile adhesive
The adhesive you should use is thin set mortar. Never use mastic, especially for floors and wet areas.
You need to remove the paint by grinding, no chemicals. Once you do that we can evaluate whether more prep is needed.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 09:03 PM
Adhesive for large ceramic tile over concerete slab GeauxCajuns82 Tiling, ceramics, marble 2 11-18-2010 06:13 PM
Newbie to 1950's house - tile adhesive removal? FixyChik General Discussion 20 01-08-2009 10:34 AM
Granite tile and BIG probs with adhesive showing through deeaa Building & Construction 6 07-30-2008 01:44 PM
adhesive for tile flooring? AndrewH Flooring 13 11-26-2007 08:58 AM
