Threshold Problem - Flooring - DIY Chatroom Home Improvement Forum
Old 11-27-2011, 06:21 PM   #1
Threshold problem
I just bought a house and we are starting one of many projects. We are opening up a wall that had a pocket door to make the doorway into the kitchen wider. I have to make the to floors meet but the problem i am running into is that there is no threshold wide enough. I need a wooden door threshold to be 7 inches wide and a 1in drop between the 2 floors. Does anyone know how i should tackle this. Thanks,
trizz5253 is offline   Reply With Quote
Old 11-27-2011, 06:27 PM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Design and draw a sketch of what you are trying to accomplish.
Take a couple of pics.
Post it here and we'll help you out.
or hire a carpenter/millwork guy.....
tcleve4911 is offline   Reply With Quote
Old 11-27-2011, 06:36 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 52
Sounds like you need to trim a 1"x 8" and round over the edges.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Adhesive for Marble Threshold Twister Flooring 11 05-14-2011 02:20 PM
Threshold at the front door and Tile abedj Carpentry 4 08-28-2010 04:36 PM
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 01:38 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
