Old 06-29-2007, 10:45 PM   #1
Threshold between tile and vinyl
We are installing a tile floor in our laundry room and need some sort of threshold between the new tile and the existing vinyl in the kitchen. What type of threshold is recommended?
tzibello is offline   Reply With Quote
Old 06-30-2007, 09:42 AM   #2
Tile and Paint contractor
You can use a "reducer" transition strip.
Schluter makes them in an assortment of metal finishes and sizes.
The stip is installed underneath the tile and set in thinset.
Here's a picture of a reducer strip. It's between tile and carpet, but the idea is the same. The strip transitions between a higher tile surface and a lower vinyl or carpet floor covering.
Matt | tile contractor
Charlotte, NC
MattCoops is offline   Reply With Quote
tile on vinyl floor. jkbitner416 Remodeling 6 01-23-2007 07:46 PM
Polyuerthane on vinyl tile? Krichton Flooring 6 01-19-2007 02:07 AM
Vinyl tile over luan? irishghandi Flooring 1 03-08-2006 03:46 PM
Tile over vinyl hmc Flooring 7 10-26-2005 12:05 AM
