Threshold - Flooring - DIY Chatroom Home Improvement Forum
Old 11-08-2010, 12:04 PM   #1
threshold
Need to install a threshold before my home inspection. Just purchased the standard 36" basic threshold but am now wondering if I should use a baby threshold or t molding instead. I have two thresholds both going from laminate to hard wood (laminate sits a bit higher than the wood). Question is -- which style type is most often used/easiest to install in this situation? thanks
tpfo is offline   Reply With Quote
Adhesive for Marble Threshold Twister Flooring 11 05-14-2011 02:20 PM
Threshold at the front door and Tile abedj Carpentry 4 08-28-2010 04:36 PM
Should I chance removing this threshold? rosemonster Building & Construction 7 08-22-2010 10:34 PM
New Door with Wood Threshold Over Limestone BigJimmy Building & Construction 1 02-08-2008 06:36 AM
Threshold problem from bedroom to patio Not Sure Carpentry 11 11-07-2006 08:16 PM
