Threshhold Problem With New Hardwood Floor. - Flooring - DIY Chatroom Home Improvement Forum
Old 01-13-2012, 04:07 PM   #1
Threshhold problem with new hardwood floor.
New hard wood floor placed over existing floor raising the height of floor. Old thresh hold was removed. Installers slanted wood at thresh hold area down toward where the old threshhold was toward storm door. Shaved interior door slightly. Putting felt on the door botton will drag on interior floor and still nothing to but up against when door is closed. I can not put rug on inside floor by front door no clearance because floor was raised. This does not seem right to me. How should the thresh hold be corrected. The installers are coming by tomorrow I need to be able to state this needs to be corrected. Hope I explained my problem well enough.
joyceg is offline   Reply With Quote
Old 01-13-2012, 04:52 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Original threshold should have been replaced after modifying jamb and cutting door down.
If door couldn't be cut down, the whole thing needed to be removed and replaced over floor.
titanoman is offline   Reply With Quote
Old 01-13-2012, 10:51 PM   #3
Thanks for the help, I will discuss this with the installer.
Old 01-13-2012, 11:25 PM   #4
Rewards Points: 13,450
What type floor did they put this over? I've never head of hard wood going over anything but 3/4" subflooring.
A picture would sure help.
Is this a real flooring company doing this for you?
What's the door made of?
oh'mike (01-14-2012)
Old 01-14-2012, 08:00 AM   #5
thresh hold problem
The hard wood floor was placed over old hard wood flooring. The front door is wood so it could be adjusted. I believe the storm door could be adjusted also. The company has been around for a long time. GetAttachment.aspx.jpg
This is a picture of thresh hold. sorry picture is sideways.
Old 01-14-2012, 08:29 AM   #6
thresh hold problem
This is a better picture of thresh hold problem.
Old 01-14-2012, 08:36 AM   #7
Disabled wood vet
titanoman's Avatar
The installers should have known this was going to be a problem.
It's just wrong.
Old 01-14-2012, 08:44 AM   #8
thresh hold problem
Any suggestion on how to correct this problem. They are coming at 10:30 to look at floor and my stated problem. I need to sound like I know what I am talking about.
Old 01-14-2012, 09:05 AM   #9
Disabled wood vet
titanoman's Avatar
Ask them how they expected this to work.
You think it needs another threshold raised to the heigth of the floor, over a new piece of hardwood floor, and the fiberglass (it looks like) door cut down.
They will have to mate this new piece of floor to the existing floor to your satisfaction.
Old 01-14-2012, 09:38 AM   #10
thresh hold problem
Thank you for your input. I feel more confident speaking with the installers. I have a better idea of what should of been done and what they need to do to fix the problem.
Old 01-14-2012, 09:45 AM   #11
Disabled wood vet
titanoman's Avatar
Putting new flooring over the old is what caused this problem.
But they should have told you ahead of time that the door was going to be an issue, and they may have to charge a little extra to raise the door somehow.
You may have to reach a compromise of some sort.
Good luck.
The Following User Says Thank You to titanoman For This Useful Post:
joyceg (01-14-2012)
Old 01-14-2012, 11:02 AM   #12
Find me one web site from one hardwood floor manufacturer that says it's ok to install hardwood over another hardwood floor. Not going to happen.
It would throw off the baseboards, all the other floors, and doorways as you found out. It's just wrong.
If the door is fiberglass or metal the door can not be cut.
The whole rough opening would have to be redone to get this to work out.
Any real floor installer would have know all this before they even started.
joyceg (01-14-2012)
Old 01-14-2012, 11:24 AM   #13
thresh hold problem
All this information has been so helpful. The thresh hold is going to be completely redone, and the wood door trimmed. I have learned a lot. Thanks again.
Old 01-14-2012, 11:28 AM   #14
Disabled wood vet
titanoman's Avatar
You're welcome.
Old 01-14-2012, 11:30 AM   #15
There going to have to remove some of that flooring and install an adjustable threshold and add a sealing strip to the bottom of the door.
The way it is now there is no way to seal the bottom of the door and if you did add a sweep it would be dragging on the new floor.
An adjustable threshold will raise the height by at least 1-1/2" so the door would clear the floor.
unique problem with hardwood floor seanbellay Flooring 15 05-02-2010 06:53 PM
Problem with stain on Laminate Floor Lilypebbles Flooring 4 11-04-2009 04:06 PM
Carpet on hardwood floor, threshold hoozgrunt Flooring 1 07-15-2009 09:53 AM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 07:06 AM
Hardwood floor duct opening repair gshock Carpentry 4 07-28-2007 11:57 PM
