Old 06-28-2009, 11:33 PM   #1
Default thoughts on waterlox?
Hey folks, anybody ever used waterlox? I'm either going to finish my living room of 400 square feet of 3 inch read oak in waterlox or oil based poly. Anybody used waterlox?- I do a lot of furniture building and use danish oil for most of it and I'm kind of thinking waterlox is for people who like that kind of look. I really don't want to wait a week or so for it to dry and obviously I want the floor to look good and be protected, so I'm leaning toward poly but intrigued by waterlox. thanks as always for any advice
adjason is offline   Reply With Quote
Old 06-29-2009, 09:10 AM   #2
I finished a hickory floor, custom stairway & trim with it about 10 years ago for a client. Easy to work with & very forgiving. I was back on the floor last summer doing some more work for him. It had held up pretty well.
He was insistent that I use waterlox is the only reason I applied it. His reasoning was it's easy ability to make repairs himself.
Personally, I'm an oil base poly guy myself.
pinwheel45 is offline   Reply With Quote
Old 07-01-2009, 08:44 PM   #3
thanks for the reply
More On This Topic
Ok. Now, I'm going to finish this with a Danish Oil Finish. There's several kinds of different oils you can use. Boiled linseed oil, if you do use linseed oil make sure it's boiled or else it won't work. There's tongue oil, walnut oil, all kind of... Read More »
Hi, I'm Jon on behalf of Expert Village. In this video clip we'll be staining our project. Now that our project has been fully assembled and we have sanded all of the faces and edges of it, we are ready to put stain on. I'm going to start on one of the... Read More »
Danish oil provides a penetrating finish and imparts a luster that can enhance your oldest furniture and woodwork. Applying the oil requires some prep and a number of steps, but the process can be done without any professional help. Read More »
So if you feel like you want to add more fat, healthy fats to your diet, it's important to know where this healthy fats are coming from. Like I said before you want to try and get more mono saturated fats and poly saturated fats. When you look at the... Read More »
Cleaning Wicker Furniture
Cleaning Wicker Furniture by Expert Village
For wicker furniture, you can use a warm, soapy rag and just wipe down on the surface of all the furniture. To get inside the crevices you can use a soft bristled brush, this one you can just buy at Wal-Mart or whatever, and get inside each one of the... Read More »
Your thoughts on my wood burner whatsthis General Discussion 3 04-29-2009 11:01 AM
Thoughts on this addition? sportinwla HVAC 13 04-20-2009 06:12 AM
Sizing thoughts moneymgmt HVAC 3 10-28-2007 08:57 PM
Thoughts on Cheap Flooring Idea Needed! MissyM Flooring 4 09-01-2007 09:51 PM
Thoughts on Pergo Select and Wilsonat Estate flysndoc Flooring 5 01-24-2007 02:13 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
