Thoughts And Opinions On "Trafficmaster Allure" Flooring From Home Depot? - Flooring - Page 54 - DIY Chatroom Home Improvement Forum
Old 09-13-2012, 10:56 AM   #796
Originally Posted by Big-Foot View Post
Just curious if you rolled the floor with a heavy roller?
Is this a basement floor?
Regards - Randy
No we didn't use a roller.. its likely a installation error... although...it the seam wasn't visible on Monday after install.. it wasn't until Tuesday that i saw it .
Its a very small separation... the pic actually made it look larger that what it actually is .. so i will likely either patch it with colored caulk or shave a slither of another piece and try to glue it .
mel8700 is offline   Reply With Quote
Old 09-13-2012, 12:26 PM   #797
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 148
You are supposed to roll it. You probably will have more problems. I know the warranty is voided since you didn't roll it.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 09-13-2012, 12:58 PM   #798
How do you figure that ?.. I have a copy of the owners manual. it does not list a roller needed under the tools list .
Old 09-13-2012, 02:22 PM   #799
fdf
There was nothing about rolling the floor in the instructions when we laid our Allure flooring...which is one of the reasons why so many folks use this flooring...it's easy to install and you don't need to roll it.
fdf is offline   Reply With Quote
Old 09-15-2012, 04:42 PM   #800
Anybody installed this on stairs? Any suggestion on what is the best choice for stairs which saves the cost on the long run?
diy1618 is offline   Reply With Quote
Old 09-15-2012, 05:00 PM   #801
fdf
I'm not sure about using this on stairs because you have that sticky edge to line up om each piece...I'd think with cutting them to fit a step, you'd loose that ability of the pieces to stay put...but, who knows?
You might try getting on the Allure flooring web site and if they don't have the info there, get in touch with customer service...or call Home Depot.
Old 09-15-2012, 05:15 PM   #802
Rewards Points: 258
It is my understanding that Allure is meant to be a floating floor. As such it is not suited as a stair covering. Could it be successfully glued to a stair tread? Possibly, but it would definitely not be my first choice.
retired guy 60 is offline   Reply With Quote
Old 09-15-2012, 06:53 PM   #803
Rewards Points: 148
From the installation instructions
"Rolling is recommended, when the installation is complete."
Old 09-16-2012, 09:10 AM   #804
fdf
As for rolling the flooring...maybe the slate floor is different than the wood look flooring...again, we didn't roll it, been nearly 2 yrs and no problens with it.
Barbara472...I said in my posts...we have 2 big dogs, in fact for the first year with this flooring, we had 3 big dogs, live on a farm, and th dogs tear through the kitchen a lot...so far, no a scratch!!
Old 09-16-2012, 10:13 AM   #805
Rewards Points: 148
Just saying, if you don't roll it and have proof that you did, there is no warranty. Been thru that with a friend. And I didn't install it, I loaned him my roller.
Old 09-16-2012, 10:40 AM   #806
fdf
Well, guess we're screwed then ....by time our floor gets worn or starts to come up, which I serioulsy don't think it will...a new floor will be in order!!
Old 09-16-2012, 11:30 AM   #807
Rewards Points: 148
After 2 years you should be OK. But not everyone will be that lucky. They should understand that it should be rolled, the manufacturer says to roll it.
Old 09-16-2012, 08:38 PM   #808
fdf
Lucky...guess so, then!!
Roll that floor dudes & dudetts
Old 09-27-2012, 03:06 PM   #809
Mold
Just stumbled onto this thread. Installing a laminate on a concrete basement subfloor. Laminate has padding attached, so will be laying a thin sheet of moisture protection. No moisture issues in the basement, but I'm worried about mold between the floor and sheet. What are the options? Some sort of anti-mold application on the floor?
I don't imagine we'll have a problem, but reading this thread has made me paranoid. Rusty, any thoughts?
gwill is offline   Reply With Quote
Old 09-28-2012, 08:19 AM   #810
Allure Ultra Personal Experience with product in your home
I have a HD flooring estimate for the Trafficmaster Allure Ultra product for my home. HD has a whole house installation price that has prompted me to bite the bullet and have it installed. I would love to hear from those of you who have had this product installed in your home for at least several months and whether or not you are satisfied with the way the product is holding up to day to day use. Thanks
srcgrace is offline   Reply With Quote
Tags
allure , trafficmaster , vinyl flooring
