Old 04-25-2009, 09:53 PM   #166
Thoughts and opinions on "Trafficmaster Allure" flooring from Home Depot?
Hi there,
I bought Corfu tile style Allure flooring as well. Plan to install next weekend, although finding out it needs to "acclimatize" for 48 hours may delay that. I am installing it in my boyfriend's home, which is four hours away. Anyway, I have a couple questions about this tile style floor. Hope you can answer:
1. Should the tiles be staggered (like the faux wood) or lined up with each other?
2. I am doing a kitchen, short stairway to a landing and then a full stairway....anyone have anytips on how the tile squares should be lined up from floor to stairs then back to floor?
3. I don't understand what everyone is talking about laying the first row (maybe i'll get it when i start but...) Can anyone give a detailed instruction about laying the first row?
4. The Home Depot guy didn't mention renting a hundred pound roller. How essential is this?
Thanks for any and all replies
firsttime is offline   Reply With Quote
Old 04-25-2009, 09:58 PM   #167
when installing the first row you will need to cut off the end that goes to the wall, leaving the glue end exposed. You should try and post some pics so we can give you the best advise possible
cheers
fixrite is offline   Reply With Quote
Old 04-25-2009, 10:10 PM   #168
The home depot guy let me cut a sample.
All you do is score it and then snap it.
Don't cut it thru.
It's actually what sold me.
Old 04-25-2009, 10:28 PM   #169
Here you go, Fixrite.
I guess the circa 1979 linoleum speaks for itself huh?
Old 04-27-2009, 02:37 AM   #170
May
Wow, from reading all the glowing testimonials on the Home Depot website to some of the horror stories here and on a couple of other websites, I have to say I'm thinking of just sticking with glue-down tile. We have converted our garage and have been looking for something inexpensive for the floor in the small office and an entryway for the family room. We have an expansion joint in the middle of the family room, so anything but carpet over that is a no-no. It truly does sound like it is all or nothing with the Traffic Master and we can't afford a do-over! I really appreciate everyone's input. I laid some cheap peel and stick vinyl in our kitchen as an interim floor 4 years ago and it is looking worn, but is still a pretty floor, so I may go with a little higher grade of that. Any suggestions about what is better over concrete? The garage is now heated, so that shouldn't be an issue. Also, the floor in the office needs to be able to stand up to very heavy storage buckets stacked on it (each stack being around 120 lbs.). Porcelain tile made sense, but I'm afraid I may have some spots that are not quite level and I don't have the skill to fix that! Thanks for any ideas!
May is offline   Reply With Quote
Old 04-29-2009, 05:05 AM   #171
Well, maybe not ALL!
I am amazed at how well this went down, and how soft it feels underfoot. I laid it on OSB and it feels smooth as silk. Once we got the cutting down, it went VERY quickly. I did a 19 x 10 room, plus a closet and vanity area in 7 hours. That was me laying the tile and my husband cutting it. Once we got a rhythm, we rocked it out!
He rolled it the next day, even though the directions said it was optional for residential use, we wanted to be safe. My 91 year-old father-in-law moves in this weekend, and we couldn't be more pleased with how this floor will work for him.
Had I known this product existed before I laid ceramic tile in my kitchen, Allure would be there now. I will be putting it in my bathroom when we remodel that.
Thanks to everyone for their help!
JackofallMasterofnone is offline   Reply With Quote
Old 05-05-2009, 05:32 PM   #172
I have it installed in my basement over concrete. It has been there for approximately 3 years. I love it. I am now considering a similar floor for my kitchen. I have seen some that looks like stone that I would like to investigate. Good luck.
Linanart is offline   Reply With Quote
Old 05-06-2009, 06:19 AM   #173
We installed two colors of Allure Trafficmaster in our basement: Cyprus and Corfru. Both were installed at the same time of the year. Our basement is heated between the recommended temperature range. Both colors were kept in the area where they were to be installed for days before installation began. The Corfru color is doing well. It was installed before the Cyprus. We liked the product so much that we decided to finish the basement with Cyprus color. However we are now having a problem with the seams separating with the Cyprus colored tile. Some have now seperated up to 1/8 of an inch. We want to install some Chocololate colored tiles but hesitate to do so until this problem is solved.
olduser56 is offline   Reply With Quote
Old 05-08-2009, 06:14 AM   #174
dEAR DAN-ABBY, i AM RIGHT IN UNDERSTANDING THAT YOU LAID ALLURE FLOORING OVER A HEATING FLOOR. iF SO WHAT FLOOR COVERING DID YOU USE, HARDWOOD OR A VINYL. i AM LOOKING AT LAYING ALLURE FLOORING OVER A CONCRET FLOOR WHICH PROVIDES THE HOUSE HEATING DURING THE WINTER. i AM CONCERNED AT THE VINYL EXPANDING OR SOFTENING AND OF THE EFFECT OF THE HEAT ON THE GLUE. i CANNOT FIND THE ANSWERS TO THESE QUESTIONS. wHEN i ASKED THE SALESMAN FOR THE CO-EFFICIENT OF EXPANSION i MIGHT AS WELL HAVE BEEN ASKING FOR THE LATEST INFORMATION ON NUCLEAR PHYSICS. REGARDS, Aussie Peter
Aussie Peter is offline   Reply With Quote
Old 05-10-2009, 06:25 PM   #175
Hi. We are considering replacing some of our carpet with allure flooring. I've scanned through this thread and don't really see any answers to the question: What do you use to transition between the carpeted rooms and the allure flooring? What if you're transitioning b/t the allure "wood" flooring and allure "tile" flooring? (we're considering doing our kitchen too) Also, I read about the hair dryer closing up some of the divets in laminate flooring, but didn't see a reply what to do about holes in cement. And then, just to make sure, we need a knife with new blades and a carpenters square? Anything else? Thanks
CAThorn is offline   Reply With Quote
Old 05-10-2009, 09:14 PM   #176
CAThorn, we just have our allure flooring butting up to where the carpet starts without a transition strip and it's working out fine (been 7 months now) we do have short shag carpet so don't know if that made a difference. We do have an area where it butts up to some short office-type carpet and for that I definitely needed a transition strip. Bought it at Home Depot for about $6 or so and though the fake wood on it doesn't match my flooring exactly you can't tell at all, it looks fine. I'd be happy to email you pics, just let me know. or I'll try to post some on this site.
annie68164 is offline   Reply With Quote
Old 05-13-2009, 12:04 PM   #177
Installed it over 2 years ago in two bedrooms and an adjoining bath. We had a dog with bladder cancer and installed Allure because of the accidents. This has been a great product. Affordable, easy to install, easy to clean, looks great and holds up well.
kgizo is offline   Reply With Quote
Old 05-13-2009, 12:14 PM   #178
Hi KGizo,
So your dog had accidents on this flooring and it help up ok? I would really love to put down this flooring and the dog pee is my only concern.
Thank you!
Kevin
sleighbor is offline   Reply With Quote
Old 05-14-2009, 09:56 AM   #179
Hi Kevin,
It is very easy to clean up accidents. In fact, I think they should sell it in PetSmart instead of Home Depot because it is perfect for pets. It takes a couple of minutes w/ a swiffer to clean up the hair. Much better than carpet for allergies. For the accidents I use water and/or Armstrong depending on how quickly I discover it.
With the wood texture it is easier on my dogs and cat too (I have chihuahuas and their feet slip out from under them on wood/tile). Like most new flooring, it had a smell for a few days after installation. So if you plan to have your pets in the room I'd recommend installing at a time you can have the windows open.
One bonus I wasn't expecting is that I like it better b/c it is softer on my feet than tile. And, in the winter it doesn't get cold like tile.
Good luck!
Old 05-14-2009, 10:22 AM   #180
Excellent! I was thinking the same thing about it being softer than tile. My dog sleeps on the floor and that would be better for her. Thank you for the info. It is really helpful and with this I am going to go with this flooring.
Kevin
Tags
allure, trafficmaster, vinyl flooring
More On This Topic
Hi, my name is Faith and I’m here at Flat Fork Studio, and I’m going to show you how to use a tile saw. Also, I’m going to make an attempt to cut this rooster in half because I’d like to have part of this for a mosaic project that... Read More »
Vinyl tiles are one of the most commonly used floor coverings in homes today. The flooring comes in a variety of colors, textures and styles. Vinyl tiles are durable, decorative and easy to maintain. Follow the steps below to keep your vinyl floor in... Read More »
Learn How to Assemble Lava Tiles in Heroscape Expansion sets in this free wargaming instructional video from our Hero Scape expert and gaming authority. Read More »
One of the best changes or upgrades you can make to your home is adding or changing the tile in your kitchen or bathroom. Before you can begin this type of upgrade, you must first buy your tile. Read More »
How to tile the floor in Cinema 4D; learn more about 3D animation, modeling, and rendering software in this free instructional video. Read More »
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
