Thoughts On 2 N 1 Underlayment - Flooring - DIY Chatroom Home Improvement Forum
Old 08-05-2009, 01:23 PM   #1
thoughts on 2 n 1 underlayment
I'm gonna be installing laminate wood flooring in my livingroom. We have a cement subfloor and we want to use soundproof underlayment. All the stores I've been too only sell the 2 n 1 soundproof underlayment. The only place I can find them seperate is online.
I'm also not sure about the moisture barrier. It looks so flimsy on the 2 n 1. Could I just use a 6 mm under it, just to be sure, or is it too much??
I would really appreciate any input on this. I dont want to wait for the flooring if I buy it online but I will if its a better choice.
Thanks!
janet.giron is offline   Reply With Quote
Old 08-05-2009, 11:18 PM   #2
I'm using Floor Muffler and am pleased so far with it in the two rooms that I've completed. I ordered the kind with the seal, which made joining the seams easy but the plastic makes a little noise when you walk over it if it doesn't lay perfectly flat (and it's difficult to tell if it is). The first room was finished a couple of weeks ago and we've noticed that the plastic makes less and less noise. I tried taping the plastic strip to the slab in the second room and there's only one spot with a small crinkle (it really isn't as bad as it sounds).
Tess is offline   Reply With Quote
Underlayment under laminate sanramonvalleyfitness Flooring 4 12-31-2008 09:56 PM
LAMINATE STAIR: with or without underlayment nathan.tran Flooring 1 08-19-2008 02:24 AM
Underlayment height for tile / carpet.... scheenstra Flooring 2 04-23-2008 01:12 AM
Is Cork underlayment the best for a floating engineered floor project? lgkinney Flooring 2 04-05-2008 04:17 PM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 08:39 AM
