Old 03-27-2008, 12:12 PM   #1
Default Thomasville Engineered Flooring Durability
Hi everyone,
I'm considering installing Thomasville's Walnut engineered flooring from home depot throughout my home and in reading what little I can find about this product, I have some concerns about durability. I would LOVE to hear from anyone that has installed any of Thomasville's engineered flooring (especially the walnut) that can share what they've experienced with the floor over the time since they've had it installed. Specifically, does the floor dent and scratch easily? I have a large dog and cat that are constantly running around and while I know I will get some scratching due to this (I've had solid wood floors in the past), if Thomasville is much more prone to pick up small scratches/denting I should probably look at something else. Does it hold up as well as any other product you might have experienced?
Thanks and I look forward to input anyone can provide!!
Jstrick5 is offline   Reply With Quote
More On This Topic
Many people are choosing wood flooring for their homes. This type of flooring is durable, easy to take care of and pleasing to the eye. There a two basic kinds of wood flooring: hardwood and laminate. Choosing the right wood flooring will add value to a... Read More »
Hard wood floors require little maintenance to stay attractive and durable. There are a few ways to maintain the look easily without damaging the wood, and there are a few things to avoid. The primary way to care for hard wood is simply to clean them... Read More »
How to Pick Ceiling Fans
How to Pick Ceiling Fans by Expert Village
Hello! My name is Adolph Ramirez from Tampa, Florida and on behalf of Expert Village, this is how to install a ceiling fan. Some of the things that you need to consider before selecting a new fan for your home are fan size height from the ceiling, blades... Read More »
Hi, I'm Doug. I work with twenty great guys in St Louis at Doug Jenkin's Custom Hot Rods, and we're going to do some work for you today on Expert Village. Now we're going to install the transmission on the back of the engine. On a custom installation... Read More »
Even the most knowledgeable used car salesman will give you more money for a trade-in if you take the time to clean your car beforehand. By having your car detailed inside and out, you show the car dealer that you're serious about getting a good deal on... Read More »
Engineered Flooring Install Question funktional Flooring 2 01-04-2008 05:45 PM
Engineered Flooring Doorway Transitions? GaryD Flooring 1 12-21-2007 07:06 PM
engineered flooring - advice please colbard Flooring 2 10-29-2007 12:25 AM
Engineered Flooring in Kitchen Hages Flooring 1 03-29-2007 03:30 PM
Flooring hardwood v engineered or laminate skits Flooring 1 07-12-2006 11:03 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
