Is Thinset Waterproof? - Flooring - DIY Chatroom Home Improvement Forum
Old 11-14-2011, 03:12 PM   #1
Is thinset waterproof?
I have slight dampness on my concrete slab. I want to ceramic tile over it using thinset. Should I Drylok it first? Other posts say to REMOVE Drylok. Will the thinset alone keep moisture out from underneath the slab?
royboytn is offline   Reply With Quote
Old 11-14-2011, 03:41 PM   #2
DIY staff
Rewards Points: 7,174
Thinset is unaffected by water and will not let go of the tile or concrete if subjected to water.
It is not 'waterproof' --water will pass through it---so if you have moisture coming through the slab it will eventually work it way up to the back of the tile---grout will allow water to pass---
The thinset might not bond well to Drylock---
royboytn (11-14-2011)
Old 11-14-2011, 03:44 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 388
Hi Roy,
Thinset mortar is waterproof in that; it can be used in wet areas such as a shower or outdoors.
Impossible, but maybe you didn't meant to say "from underneath the slab".
Thinset will not prevent water from going through it from either the top or from below. It is not a waterproofing.
In addition all surfaces must be in proper condition and dry. It sounds like you have a moisture problem, thinset nor anything else will cure that. Furthermore you shouldn't install anything until it's corrected. Trapping moisture under tiles or any other floor covering will cause mold and rot.
This is what one of the thinset manufactures has to say on the subject.
Concrete must be free of efflorescence and not subject to hydrostatic pressure.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
White thinset and Gray Thinset, does it really make a difference.. yummy mummy Tiling, ceramics, marble 25 02-03-2012 11:00 PM
questions about thinset ponch37300 Flooring 16 03-16-2011 11:45 AM
glass tiles over kerdi (thinset question) Queso Bandit Tiling, ceramics, marble 1 04-17-2009 12:39 PM
Fortified Thinset poolecw Flooring 4 10-31-2008 07:06 AM
Thinset application question poolecw Flooring 2 10-15-2008 03:51 PM
