Thinset To Use With Porcelain? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-17-2009, 02:13 PM   #1
Thinset to use with porcelain?
First time tiler about 1/3 the way through my living room w/ 13 x 20 porcelain Dal-tile on top of Hardibacker. I just realized that I was using the pre-mix thinset I bought for the Hardibacker to subfloor bond for the porcelain. How big of a problem do I have? What kind shoud I switch to? Thanks!
pf55112 is offline   Reply With Quote
Old 05-17-2009, 02:38 PM   #2
Oldguy
Rehabber's Avatar
You need to take up the tile you have already laid and wash everything down to remove ALL of the premixed garbage.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 05-17-2009, 07:33 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 198
Aren't DIY projects fun, sometimes?
Why did you use mastic to install the Hardie in the first place? That stuff is much more expensive and not as good.
It's definitely no good to set the tiles. Once you're ready to start over, get a decent quality modified thin set mortar. A "basic" grade starts at about $13 per bag. The better ones in the twenty plus range. The are many brands and they should all be good. Some are just better than others. We don't know what brands are available near you.
Jaz
questions about thinset ponch37300 Flooring 16 03-16-2011 12:45 PM
Fortified Thinset poolecw Flooring 4 10-31-2008 08:06 AM
Thinset application question poolecw Flooring 2 10-15-2008 04:51 PM
Porcelain on Cast Iron Tub controlnovice Plumbing 1 08-16-2008 11:36 AM
8 x 17 Porcelain Wall Tile steve65 Flooring 4 03-19-2008 11:26 PM
