Thinset Under Hardi Backer - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-08-2008, 12:56 PM   #16
Rewards Points: 150
i have since read that if you use plywood it should be exterior grade.
drewhart is offline   Reply With Quote
Old 11-08-2008, 02:07 PM   #17
JJC
Pro
True it should be Exterior Glue Plywood.(EGP) All this does is help hold the laminated layers together while the moisture from the thinset expands the wood and then when the thinset dries the wood layer shrinks back to size. Think about the stress put on the layers of wood and thinset as they go in one direction and then return to hopefully the original position.
JJC is offline   Reply With Quote
Old 11-08-2008, 04:08 PM   #18
Drywall contractor
Rewards Points: 1,070
Read the tile mfgr's. instructions for proper backing. I'll bet not one lists plywood as an acceptable substrate for tile.........you'll void any warranty if you don't follow the recommendations.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 11-08-2008, 04:29 PM   #19
Most support exterior grade, but interior or OSB is not recommended.
jerryh3 is offline   Reply With Quote
Old 11-08-2008, 05:18 PM   #20
Drywall contractor
I stand corrected, I would have thought cement board was the standard........that's what I get for thinking.
Old 11-08-2008, 08:01 PM   #21
Get out of the box!
Rewards Points: 260
Use Ditra!
All this hassle.....
Come on you guys just use Ditra!
One little tidbit of info that might interest you is:If you do not damp mop the hardibacker prior to the tile install and the floor fails:
You have no warranty!
And....... they can tell if you a have done it the right way!
Betcha ya did'nt know that!
Don't feel bad most people don't know.
Use Ditra! It solves all these issue.
26yrsinflooring is offline   Reply With Quote
Old 11-08-2008, 09:09 PM   #22
motivator
Speedball's Avatar
I checked out the Ditra website and it is an interesting product. A little video showing it may be a very easy product to work with.
Speedball is offline   Reply With Quote
Old 11-09-2008, 03:05 AM   #23
"I'm wondering if you have to let the thinset dry before you screw down the Hardi backer? And is there a right and wrong side to the Hardi backer?" Answer to your question: don't let it dry,yes there is a wrong and right side,you cann tell which side goes... common sense
detroitMi is offline   Reply With Quote
Old 11-09-2008, 11:57 AM   #24
Maybe you CAN tell which side goes...but why would someone ask if they already knew?
Divinepoodles is offline   Reply With Quote
Hardie backer board DXS General DIY Discussions 2 03-17-2009 05:40 PM
Fortified Thinset poolecw Flooring 4 10-31-2008 07:06 AM
Thinset application question poolecw Flooring 2 10-15-2008 03:51 PM
Thinset under concrete backer board? dankreboot Flooring 15 06-06-2008 03:55 PM
thinset on thinset? boman47k Flooring 4 10-10-2007 06:32 AM
