Thinset Under Hardi Backer - Flooring - DIY Chatroom Home Improvement Forum
Old 11-05-2008, 06:31 PM   #1
Thinset under Hardi backer
I'm wondering if you have to let the thinset dry before you screw down the Hardi backer? And is there a right and wrong side to the Hardi backer?
Divinepoodles is offline   Reply With Quote
Old 11-05-2008, 06:58 PM   #2
motivator
Speedball's Avatar
I'm not an expert but why would a person put thinset 'under' hardibacker?
Speedball is offline   Reply With Quote
Old 11-05-2008, 07:49 PM   #3
Because you're supposed to. Screw the hardibacker down while the thinset is wet, then get off of it and let it dry overnight. Most 1/4" hardibacker I've seen has a grid and screw pattern on the "up" side.
jerryh3 is offline   Reply With Quote
Old 11-05-2008, 07:53 PM   #4
remodeling pro
It fills the minor low spots in the substrate, thus eliminating the potential for an area that could flex under load, and when the backer is fully bonded to the substrate, it is much more solid. Of course this step is skipped more often than it is done, even though all cement backer manufacturers state to do this in their instructions.
Generally the rough side is up for thinset applications, and the smooth side is up for mastic applications. This is found either on the label stuck to each board, or sometimes printed directly on the product.
troubleseeker is offline   Reply With Quote
Old 11-05-2008, 07:54 PM   #5
JJC
Pro
Speedball,
Because it is a requirement of the hardibacker manufacturer. Actually all cement board manufacturers state this in their literature.
Divinepoodles,
You want the thinset to be wet because the board needs to bed into it and it helps take up any variations in the floor. then mechanically fasten the board while it is wet. One side of the board has indents to help people locate the required spacing between fasteners.
JJC is offline   Reply With Quote
Old 11-05-2008, 08:40 PM   #6
Thank you all for the help. It all makes sense now.
Old 11-05-2008, 08:40 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 422
Speedball,
That's a fair question coming from you, a regular homeowner DIY'er. Problem is there are many tile installer "Hacks" that ask the same question. Those guys are ripping their customers off with poor workmanship.
Jaz
Old 11-06-2008, 05:23 PM   #8
motivator
Speedball's Avatar
Appreciate the good replies and no, I'm not in the business.
Old 11-06-2008, 07:29 PM   #9
Rewards Points: 150
instead of backer board, we put 1/2" plywood down for 5 x 9 bathroom floor. we put a million screws in the plywood to minimize any movement. is this bad? i'm not in the business either. it feels solid.
drewhart is offline   Reply With Quote
Old 11-06-2008, 07:34 PM   #10
motivator
Speedball's Avatar
Drewhart,
What was just under the 1/2" plywood?
Old 11-06-2008, 07:39 PM   #11
Rewards Points: 150
nothing. just kidding! 3/4" sheathing. six inch wide boards. older, we nailed them down as secure as could first.
Old 11-06-2008, 08:49 PM   #12
Tileguy
JazMan's Avatar
Rewards Points: 422
Drew,
Plywood as the underlayment in a bathroom is not a very good idea. It's not a good method anywhere, but it can work in dry floor installations. Tile doesn't make the floor waterproof you know?
Jaz
Old 11-06-2008, 09:25 PM   #13
Rewards Points: 150
is backer board waterproof? in new constuction i have rarely seen anything other than plywood used. my parents house has four bathrooms. the house is fifteen years old and there has never been a problem.
Old 11-07-2008, 05:53 AM   #14
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
The concrete based backer boards are not waterproof, but they are dimensionally stable when it comes to moisture. Wood is not. It will expand and contract as moisture content changes. Now you could put a membrane like Ditra over the plywood and it will make it much more waterproof and uncouple the tile installation from the wooden subfloor.
poppameth is offline   Reply With Quote
Old 11-07-2008, 07:52 PM   #15
motivator
Speedball's Avatar
I'm getting ready to do the exact same thing!.... only maybe screw the boards down. Then plywood....but if something is better I need to find it.
Hardie backer board DXS General DIY Discussions 2 03-17-2009 05:40 PM
Fortified Thinset poolecw Flooring 4 10-31-2008 07:06 AM
Thinset application question poolecw Flooring 2 10-15-2008 03:51 PM
Thinset under concrete backer board? dankreboot Flooring 15 06-06-2008 03:55 PM
thinset on thinset? boman47k Flooring 4 10-10-2007 06:32 AM
