06-04-2008, 01:51 PM
#1
Thinset under concrete backer board?
Hello All,
I'm going to be installing tile on my kitchen floor which right now has plywood. I'm going to be installing a 1/4" backer board over the plywood so I can tile. My question is should I set it with thinset and screws or is screwing it in enough? All suggestions and opinions would be appreciated.
Thanks,
Dank
06-04-2008, 02:24 PM
#2
Tileguy
Suggestions and opinios don't count. READ THE INSTRUCTIONS!
ALL backerboard makers want their product set into a fresh bed of thinset, in some cases unmodified thinset.
ALWAYS FOLLOW THE MANUFACTURERS SPECIFICATIONS!
06-04-2008, 04:43 PM
#3
Not-So-Newbie
TCNA handbook is a good idea too, if you have never read one! Lots of sound info.
06-04-2008, 08:08 PM
#4
Tile Contractor
What Bud said. Use the thinset.
"Whether you think you can, or you think you can't, You're probably right."
06-05-2008, 12:25 PM
#5
I Used To Lay Tile And When Ever We Used Cement Board We Always Put Ir Down With Thinset And A Nail Gun
06-05-2008, 03:37 PM
#6
Moderator
Also mud and tape the seams with fiberglass mesh tape and thinset.
06-05-2008, 03:45 PM
#7
Oh Yeah I Forgot About The Tape And The Seams. That Helps To Prevent Cracks Ans Other Things Over The Years
06-05-2008, 05:27 PM
#8
Tileguy
Just so to not confuse others, we do NOT "mud" and tape any seams with any CBU. The proper term for the product used is "thinset". Mud is something completely different in the tile business.
I only bring this up because there are many hacks out there that use the term "Mud" when they only spread thinset to set tiles.  They are trying to deceive others to make them think they are actually doing a "real mud job" when they are not.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
06-05-2008, 06:04 PM
#9
K&B Remodeler/Tile Guy
Since this has gotten technical.....
Make sure you use an alkaline resistant tape over the backer seams. Also, make sure you stagger the seams for each row. You then use thinset over the tape and screw/nail holes.
I think between all 6 of us, we covered everything now!
Angus
06-05-2008, 06:23 PM
#10
Tile Contractor
Alkali resistant alloy screws or nails.
06-05-2008, 06:45 PM
#11
Geez,
After all of this I hope Dank even reads this
Angus
06-05-2008, 07:21 PM
#12
Tileguy
Hey....installing tiles correctly can be technical
I'm sure it doesn't hurt, but thinset over the fasteners is neither necessary nor recommended.
Jaz
06-05-2008, 07:57 PM
#13
Jaz
OK, but as a precaution. What if a fastener blasts through the bottom of the CBU or if you get too close to the edge and crack the CBU?
Besides, doing that helps keep dust and debris out of the counter-sunk screw holes. I hate dusty CBU when trying to thinset!
So point taken but I don't see how it can hurt.
Angus
06-06-2008, 04:22 PM
#14
Yes Thinset Is Used. Oh I;m So Sorry The Word Mud Came Up Thinset All The Way.
Thinset/mud Most People Know What Ya Mean
06-06-2008, 04:27 PM
#15
Tile Contractor
Javaman-- keep in mind-- this is a DIY forum. Everyone who comes in here WON'T necessarily know what's meant.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
