Old 10-09-2007, 06:37 PM   #1
thinset on thinset?
Tile cutter malfunctioned while I was tiling my bath. I also ran a few pieces short thanks to the cutter malfuntioning. To finish this project, do I have to completely clean the excess thinset left from the first attempt down to the backer board?
Old 10-09-2007, 07:43 PM   #2
Tileguy
JazMan's Avatar
thinset on thinset?
No, of course not. You removed the thinset while still fresh right?
Jaz
Old 10-09-2007, 08:18 PM   #3
thinset on thinset?
Yes, Remove the thinset.
flooring dude is offline   Reply With Quote
Old 10-09-2007, 10:26 PM   #4
Tileguy
JazMan's Avatar
thinset on thinset?
Remove the thinset??? You're kidding! There isn't a build up of thinset on the floor, just a skim coat from the remains after he removed it once he realized he had no more tiles.
If there was a build up, (the normal amount) I don't think he would be asking the question, do you? It's the same as treating the seams of the CBU.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 10-10-2007, 07:32 AM   #5
thinset on thinset?
Makes sense to me, although I did the seams as I did the tile. There is a little buildup on the edges of a few of the tiles. I will chip and scrape them down then vacuum the dust. The thinset has been down a few days , and I was concerned the new thinset might not adhere to it.
Drill to mix thinset dbrew Tools 25 08-08-2007 11:48 AM
Thinset question billinak Remodeling 2 11-24-2006 10:11 PM
How thick a layer of thinset ? Piney Flooring 2 11-10-2006 03:32 PM
Find and Remove Screws under Thinset waig Flooring 7 10-18-2006 10:40 AM
Ideas for getting up slate thinset mbur113 Remodeling 2 09-15-2006 10:35 PM
