Thinset Removal & New Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 03-26-2012, 09:19 AM   #1
Post
Thinset removal & new flooring
I am new to this area of work, and have read several threads regarding this topic, but unable to find one related specifically to my situation. I removed tiling from the kitchen floor. I now have the remaining thinset/grout to deal with. Fortunately, the guy who laid the tile did a poor job and about 1/2 of the tile just lifted off. I have heard about the rental grinder/hammer to remove the remaining thinset, but my situation is that it was applied directly to plywood. Do you feel this powered grinder would also grind up the plywood? The posts I have read dealt with the thinset on concrete.
Setting: the kitchen floor is adjacent to hard wood flooring in the dining room and living room. I am undecided with vinyl peel and stick or since I have some floating wood floor left over from another project, just to go with that.
If I go with floating wood flooring (actually, laminate, right?), since a pad is going underneath, is it absolutely necessary to remove all the thinset or just focus on the parts that have noticeably high peaks on it? Your help and response is appreciated.
timnc is offline   Reply With Quote
Old 03-26-2012, 09:29 AM   #2
Pro
JetSwet's Avatar
Rewards Points: 502
Yes if you Install laminate the floor has to be cleared of all thinset needs to be flat or it will push through the padding and make the floating floor pop up on you.
The tile installer might have mixed the thin set wrong or used the wrong kind and or used unsanded ply as well.
So grind and chisel the thin set completely off and you will be fine for laminate.
JetSwet is offline   Reply With Quote
The Following User Says Thank You to JetSwet For This Useful Post:
timnc (03-26-2012)
Old 03-26-2012, 12:47 PM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Originally Posted by timnc View Post
...but my situation is that it was applied directly to plywood.
Why not replace the plywood?
Old 03-26-2012, 06:49 PM   #4
It seems that could be quite time consuming as the cabinets would have to be removed, and it would still result in some of the plywood having to be cut. That makes me nervous since I have not done that before and it actually involves removing a very foundational piece of wood, in my opinion. Additionally, that plywood is rather expensive per sheet nowadays. Thanks for your input though. It is appreciated as all options are considered.
Old 03-26-2012, 08:05 PM   #5
Start by chiseling off as much as possible. Use a hammer drill (hammer-only setting) and a tile chisel to knock the thinset off the wood. Keep the blade shallow so you don't dig into the wood and you should be fine.
Grinding it will work it will just take a fairly long time and create a massive amount of dust. You'll be able to tell when you get down to the wood so don't worry about that. I would highly suggest a respirator, not just a dust mask for this. Eye and ear protection is also worthwhile. Make sure you plastic off the work room very well.
Polapea is offline   Reply With Quote
The Following User Says Thank You to Polapea For This Useful Post:
timnc (03-26-2012)
Flooring for hot tub room with tongue and groove base flooring. tkmiller Flooring 0 10-24-2010 01:21 PM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 09:53 PM
Scraper recommendation for vinyl flooring removal bob22 Flooring 0 09-03-2010 08:38 AM
Flooring and Baseboard Removal hammermonkey Flooring 3 01-10-2009 07:45 PM
Sheet Vinyl Flooring Removal yoods Flooring 2 11-22-2007 01:04 PM
