Thinset Removal Between Inserts(Thinset = TOUGHSTUFF) - Flooring - DIY Chatroom Home Improvement Forum
Old 02-15-2010, 03:45 PM   #1
Thinset removal between inserts(Thinset = TOUGHSTUFF)
Hi folks, I recently set a new tile floor down in the kitchen. I put in some inserts that are squares of pieces of stone betheen the tiles. The rookie I am I didnt clean out enough of the thinset between the stones and now dont have any depth to put the grout down. I tried using my dremell (sp) with a diamond bit but that thinset is some tough stuff and it wasnt long before all I had was a nub left. Any suggestions on how to grind/clean out excess thinset?.....Thanks.
nylajo is offline   Reply With Quote
Old 02-15-2010, 04:55 PM   #2
Military Mom of 4
Snav's Avatar
Been there!
I used a glazed ceramic tile with 1/8" gap and ended up cutting a scrap of wood into a wedge and just scraping it through to remove it from in between. If the fat-end of the wedge is wide then it's ok to hold in your hand - rather than using a tool and risk gouging your tiles.
(believe it or not - scraping it off like this is more effective that going at it with a bit or solvent of some type - but a tad bit time consuming)
When the gap was too small for that I used a set of small-head screw drivers (flat-head) and tapped them through with a small hammer.
I promise - you'll never forget to keep your grout gaps clean in the future!
Good luck!
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 02-15-2010, 07:47 PM   #3
firehawkmph's Avatar
Rewards Points: 1,884
Nyl,
I use a straight bladed screw driver to scrape off any high spots of thinset. I usually do this the next morning before 24 hours is up. It is usually pretty easy to do at that point. The longer it sits, the harder it gets.
Mike Hawkins
firehawkmph is offline   Reply With Quote
White thinset and Gray Thinset, does it really make a difference.. yummy mummy Tiling, ceramics, marble 25 02-03-2012 11:00 PM
questions about thinset ponch37300 Flooring 16 03-16-2011 11:45 AM
Fortified Thinset poolecw Flooring 4 10-31-2008 07:06 AM
Thinset application question poolecw Flooring 2 10-15-2008 03:51 PM
Lead paint removal Luken8r Painting 3 05-15-2008 07:05 PM
