Thinset Mortar Squeezed Up Into Expansion Joints - Flooring - DIY Chatroom Home Improvement Forum
Old 09-04-2012, 07:05 AM   #1
Thinset mortar squeezed up into expansion joints
While laying the 1/4 hardibacker on top of 3/4 " plywood in a thinset bed the mortar was squeezed into the expansion joint between one wall and the hardibacker leaving no expansion joint along that wall. Should I cut this mortar out? This is only the case on one wall. If this should be removed what would be the easiest way to remove without damaging surrounding area.
tsayles is offline   Reply With Quote
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 03:07 PM
Expansion joint john4153 Plumbing 0 10-05-2011 07:51 PM
ANSI standards thinset mortar diy888 Remodeling 1 02-09-2009 02:24 PM
granite floor tile which mortar? diy888 Flooring 10 01-23-2009 07:20 AM
Basment block mortar joints crumbling, 40's era 4just1don Building & Construction 1 09-03-2008 10:09 AM
