Thinset Help - Flooring - DIY Chatroom Home Improvement Forum
Old 11-21-2008, 01:43 PM   #1
thinset help
i am laying tile around my bath tub and now i have dried thin set in my tub. any help would do on how to clean this mess up without ruining my tub thanks ryan.
rilijic2 is offline   Reply With Quote
Old 11-21-2008, 03:12 PM   #2
All trades carpenter
Well what material is the tub? If it is any type with a porcelain coating it should come up fairly easy. I would soak it with water and use a plastic putty knife to scrape it off. Use the same method if it is fiberglass but any tub you want to take you time because you might scratch the finish!
CrpntrFrk is offline   Reply With Quote
Does cement board require thinset to the underlayment? scheenstra Flooring 7 11-21-2008 12:47 PM
Fortified Thinset poolecw Flooring 4 10-31-2008 07:06 AM
Thinset application question poolecw Flooring 2 10-15-2008 03:51 PM
thinset on thinset? boman47k Flooring 4 10-10-2007 06:32 AM
