Thinset And Grout Drying Times - Flooring - DIY Chatroom Home Improvement Forum
Old 10-31-2011, 02:58 PM   #1
Rewards Points: 211
thinset and grout drying times
How long should will it take for thinset to dry under 12 x 12 travertine? I'm using Lowe's Lacrete modified. 24 hours? How can I tell for sure that it's ready for grout?
Same question with the grout? How long til it's dry?
gtothek is offline   Reply With Quote
Old 10-31-2011, 03:33 PM   #2
A Little Of Everything
Rewards Points: 1,362
There's a difference between dried and fully cured.
I've grouted tile within 24 hours of laying it, but that was under ideal conditions. I'd recommend waiting at least 24 hours.
Same with grout.
Just note that it takes a lot longer than 24 hours for grout to cure, before you should apply sealer.
DrHicks is offline   Reply With Quote
Old 10-31-2011, 03:54 PM   #3
Rewards Points: 211
I'm a newbie so I need more finite numbers for wait time. Like 2 days, 36 hours, etc???
I was planning on laying the tile on saturday morning and grouting sunday afternoon. The tile is in a 3x6 powder room bathroom.
Old 10-31-2011, 04:03 PM   #4
That should be perfectly fine.
The majority of sealers recommend waiting 72 hours, after grouting, before sealing the grout.
Good luck!
Old 10-31-2011, 05:36 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
gtothek: "I'm a newbie so I need more finite numbers for wait time. Like 2 days, 36 hours, etc???
I was planning on laying the tile on saturday morning and grouting sunday afternoon. The tile is in a 3x6 powder room bathroom."
Assuming the temperature doesn't drop below 55 degrees fahrenheit during any of this time you will be well good to go. Thinset under travertine will "set" in a matter of just a few hours if the temperature is agreeable, and overnight will be plenty of time to stay off of it.
Grout is the same way assuming you are using Portland cement grout.
As far as sealing the grout, buy your sealer and follow those instructions that are on the label. Grout sealer applications can vary by manufacturer.
Old 10-31-2011, 10:05 PM   #6
stick a knife or sharp object into left over mortar in bucket. if your knife penetrates into mortar, let dry longer. if knife doesnt, thinset is dry.
acglobal is offline   Reply With Quote
Old 10-31-2011, 11:23 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Actually modified thinset remaining in bulk form in a bucket will take a lot longer to dry than if it is spread between two stratus in thin fashion.
Minimum Thinset Drying Time DrHicks Tiling, ceramics, marble 4 09-26-2011 05:47 PM
thinset between tiles in grout space amakarevic Flooring 2 06-10-2011 05:29 PM
Using white thinset with dark grey grout. sukhenkoi Tiling, ceramics, marble 5 04-20-2010 07:54 AM
My grout consistency....like thinset? yummy mummy Tiling, ceramics, marble 7 07-13-2009 12:52 AM
Thinset, plaster, grout - okay to store in plastic? BradG Building & Construction 1 01-25-2008 06:53 AM
