Thinset Expires? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-29-2013, 10:12 AM   #1
analogmusicman's Avatar
Rewards Points: 560
thinset expires?
they're telling me on JB that my thinset which is 1.5 years old is expired. hey Jaz you never told me that! you mean those bags of special thinset I bought are no good now? money wasted?
tnx,
analogmusicman is offline   Reply With Quote
Old 03-29-2013, 09:46 PM   #2
Rewards Points: 952
Didn't you keep them in your refrigerator?
cleveman is offline   Reply With Quote
Old 03-29-2013, 10:13 PM   #3
Rewards Points: 276
My understanig is that if it is kept sealed and dry, it will keep.
Jim F is offline   Reply With Quote
Old 03-29-2013, 11:34 PM   #4
Rewards Points: 952
The sand in it can go bad after a while. Especially if you open the package and don't seal it up again properly. Some Ungeziefer can get in there.
Same way with flour. You can get some meal worms in there.
Old 03-30-2013, 05:44 AM   #5
DIY staff
Rewards Points: 7,174
Any powder can and will go bad if it is exposed to high humidity----I do not save powders for more than a few months due to the humidity in my area---
However, if your powders were inside the house in a dry place,they should be fine----open a bag and run your fingers through it---any of it sticking together or are there 'BBs'?(little pellets stuck together)
Old 03-30-2013, 09:30 AM   #6
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Normal thinsets can go bad from drawing moisture. If sealed in the plastic bags like Mapei's they should last quite a while. Rapid Sets are a different matter. About a year from production in a sealed bag it all you get from rapid sets or leveling compounds. Rapid sets get a little difficult to work with the further past expiration they go. Leveling compounds don't level once they are past expiration. They tend to just sit where you put them. Grouts expire too. Epoxy grouts can go a year or two before the epoxy won't cure correctly. Cementitious grouts can draw moisture and clump or they can have problems with color consistency.
Darkling Designs
poppameth is offline   Reply With Quote
Old 04-01-2013, 08:44 AM   #7
Rewards Points: 150
I'm pretty sure I've seen Jaz state that you don't want to use thinset that's over a year old.
zakany is offline   Reply With Quote
The Following User Says Thank You to zakany For This Useful Post:
oh'mike (04-01-2013)
using recently mixed thinset with newly mixed thinset DiyCR fan Flooring 6 03-19-2013 08:19 AM
White thinset and Gray Thinset, does it really make a difference.. yummy mummy Tiling, ceramics, marble 25 02-03-2012 11:00 PM
questions about thinset ponch37300 Flooring 16 03-16-2011 11:45 AM
Fortified Thinset poolecw Flooring 4 10-31-2008 07:06 AM
Thinset application question poolecw Flooring 2 10-15-2008 03:51 PM
