Old 06-10-2011, 04:11 PM   #1
Question
thinset between tiles in grout space
i just completed my first ever tiling job. small mistakes and lessons learned, particularly that it is critical NOT to have too much thinset but just the right amount. i used 2" mosaic tiles
my question is what to do with the excess hardened thinset in between the tiles where grout is supposed to go. i understand that if i had used just the right amount of thinset in the first place, the thing wouldn't have spilled up into those spaces. wondering if i can do anything now to fix it.
oh, and i first tried cutting them dry with a 4.5" grinder and a diamond blade, that didn't go to well so i bought a mini MK wet saw which works perfectly.
Old 06-10-2011, 05:02 PM   #2
woodman58's Avatar
There are many tools to use to remove grout from in between tile. I use a painter's 5in1 tool. You can purchase a grout rake with a hook on it at the box stores in the flooring department. It will be a job if there is a lot but, it should do the job.
woodman58 is offline   Reply With Quote
The Following User Says Thank You to woodman58 For This Useful Post:
amakarevic (06-10-2011)
Old 06-10-2011, 05:29 PM   #3
Tileguy
JazMan's Avatar
Utility knife held at a slight angle. It's best to cut the thin set not scrape it. As long as this is not a shower floor with a surface membrane, you're good.
This happens to me too, don't feel too bad. One reason we have to charge more for mosaics.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
The Following User Says Thank You to JazMan For This Useful Post:
Tags
grout, thinset, tile
I need to buy grout and tile spacers. What is the most common space between 6x6 tiles sukhenkoi Kitchen & Bath Remodeling 6 05-02-2011 08:42 AM
How to remove thinset residue after old tiles removed? sz8 Flooring 11 01-01-2011 10:49 PM
Need to replace 4 3x3 ceramic tiles around shower. babaganoosh Tiling, ceramics, marble 1 12-28-2010 09:40 PM
epoxy grout on glass tiles? zootjeff Tiling, ceramics, marble 1 07-04-2010 08:21 AM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 04:06 PM
