-   -   thinset between tiles in grout space (http://www.diychatroom.com/f5/thinset-between-tiles-grout-space-107279/)
amakarevic 06-10-2011 03:11 PM
i just completed my first ever tiling job. small mistakes and lessons learned, particularly that it is critical NOT to have too much thinset but just the right amount. i used 2" mosaic tiles
my question is what to do with the excess hardened thinset in between the tiles where grout is supposed to go. i understand that if i had used just the right amount of thinset in the first place, the thing wouldn't have spilled up into those spaces. wondering if i can do anything now to fix it.
oh, and i first tried cutting them dry with a 4.5" grinder and a diamond blade, that didn't go to well so i bought a mini MK wet saw which works perfectly.
woodman58 06-10-2011 04:02 PM
There are many tools to use to remove grout from in between tile. I use a painter's 5in1 tool. You can purchase a grout rake with a hook on it at the box stores in the flooring department. It will be a job if there is a lot but, it should do the job.
JazMan 06-10-2011 04:29 PM
Utility knife held at a slight angle. It's best to cut the thin set not scrape it. As long as this is not a shower floor with a surface membrane, you're good.
This happens to me too, don't feel too bad. One reason we have to charge more for mosaics.
Jaz
