Thinset B4 Cement Board On OSB? - Flooring - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By oh'mike
  • 1 Post By JazMan
Old 09-20-2012, 03:44 PM   #1
thinset b4 cement board on OSB?
a couple of my buddies, who often do flooring work, told me not to put the cement board in a bed of thinset before tiling. they said to glue the cement board to the OSB then screw it per instructions. they all said the OSB will absorb the water out of the thinset and swell like a sponge and start popping tiles. true? if so, what glue do i use? ive got 2X10 floor joists then 1X8's then 3/4 OSB...am going to use 1/2 in backerboard.
second, what size trawl do i use on some 6X24 wood plank porcelain tiles? .25 or .5?
deputy is offline   Reply With Quote
Old 09-20-2012, 07:15 PM   #2
DIY staff
Rewards Points: 7,174
Use the thinset----they are wrong----the thinset is there to fill any voids and keep the backer from flexing----
To verify what I said --read the tcna manual---or look at the instructions for Durrock---
Mrbuilder likes this.
Old 09-20-2012, 09:19 PM   #3
garlicbreath's Avatar
Rewards Points: 150
I read on JB's site that you should not use OSB when tile is involved. Can someone confirm that is the case?
garlicbreath is offline   Reply With Quote
Old 09-20-2012, 09:28 PM   #4
Rewards Points: 918
I would try a .375 trowel frist, but have a 1/2" handy.
cleveman is offline   Reply With Quote
Old 09-20-2012, 09:42 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 220
Sorry, but your buddies don't have a clue in this case. But, is this 3/4" OSB subfloor grade or cheapo generic, what brand? All CBU are required to be set into fresh thinset mortar, fastened and seams taped.
Neither of those. How about .375. So, 1/4x3/8x1/4.
Perhaps you miss understood what someone was saying. OSB as a subfloor is fine. You install a backer or Ditra then the tiles and you're good. What they were saying, (or should have been saying), is that you can not install tiles over OSB.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
garlicbreath (09-20-2012)
Old 09-21-2012, 12:39 AM   #6
its going on top of 3/4" OSB t&g screwed down to the joists through the 1X8's with 3" screws. the floor is about 160 or so sq. ft. and i used almost 5lbs of screws. the markings on the OSB is Blue Ribbon 22/32" THIS SIDE UP...got it from lowes.
Looking at my sub-flooring job, i accidently have one board flipped over...does it matter?
Old 09-21-2012, 09:19 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 220
Deputy,
It's best to fasten the underlayment only to the subfloor and not the joists too. This allows a bit of separation from the twisting of the joists. Not the end of the world if you already installed the 3/4" ply since you'll have another layer over it.
We normally have you tell us how the framing is built and with what materials. Give us the; type and size of the joists, (2x10 in your case), their species and grade will help a lot, on center spacing, (usually 16"), and the span, to the inch. We will refer to a span chart and let you know.
I wouldn't worry about that one sheet much. BTW, can you confirm exactly which Blue Ribbon OSB product you bought?
Jaz
littlecleo (09-22-2012)
Old 12-26-2016, 09:50 AM   #8
Rewards Points: 26
Re: thinset b4 cement board on OSB?
I am confused about how to proceed with preparation of my floor for tile.
Background:
About 150 sf floor to cover in upstairs bathroom with separate toilet area. Construction is OSB (unknown Exposure Rating) over wood I Beams (I Beams are 12 inches wide (deep?) and seem to be spaced 20 inches apart). Longest span within the room is 11 feet – it may run out to 15 feet before there is a wall (support) below. Curiously it appears that the OSB is only nailed at joint with another sheets (not field? nailed) – I know they used adhesive on top of I Beams).
We had a leak (small drip – while gone for a week) and floor got wet. The OSB subfloor is a bit uneven now (and may have been since new). It was mostly covered with carpet except the toilet area and a “landing” area for the tub/shower. – Both of these areas were tile over inch Durock. The Durock was nailed directly on the OSB (no thinset). These two small area have held fine for 16 years (age of house) – but it still seems incorrect.
I want to do the floor prep correct as reasonably possible.
It seems a given that the cement board (all types) have to be bonded to the sub floor. This is 1st area of confusion. I have read (somewhere) not to put thinset on top of OSB – Drock website states to use latex modified thinset or Type I Organic Adhesive. And notes the OSB should be Exposure Rating 1 or better).
I guess some will say go ahead and thinset cement board to the OSB. If that is the case any thought to covering subfloor with tar paper or rosen paper? - I do not know the OSB exposure rating…
I was thinking I would cover subfloor with Luan. I like the idea that (a long time) down the road you could remove the floor “cleanly” after the Luan is removed – back to the original subfloor. But now I have read to never use Luan between OSB and cement board… - Is that true?
Next thought is to use plywood screwed to the OSB and then thinset/screw cement board- I would think that would be a very good foundation for the tile. Of note here is that I would rather not have the height build up but I am will to make that trade-off for a trouble free install.
Thanks in advance for your valuable knowledge and experience. I am OK spending a bit of extra time/money to “do the job right”. I really want to eliminate any possible future problems…
MLB1961 is offline   Reply With Quote
Old 12-26-2016, 05:32 PM   #9
Rewards Points: 26
I am trying to delete my post #8 as i posted this on a new question
how do i do that?
Old 12-26-2016, 09:12 PM   #10
Tileguy
JazMan's Avatar
Rewards Points: 220
What is the status of #8 now?
Jaz
Old 12-26-2016, 10:26 PM   #11
Rewards Points: 26
It is still there - I posted the same questions in another thread and was trying not to double post.
If you can take it down thanks
Also I would value your opinion as to my best options
thanks for your time, you seem a wealth of knowledge
Old 12-27-2016, 12:48 AM   #12
Rewards Points: 26
#8 is still there - I post this a a separate thread and wanted to delete this one - so as to not double post.
New Roof but Fascia Trim Board Rotting ein0801 Roofing/Siding 6 07-15-2012 01:21 AM
how to hang plastic behind shower cement board 4just1don Building & Construction 2 07-22-2011 12:34 PM
Cement board meets drywall? CowboyAndy Drywall & Plaster 8 12-25-2010 09:29 PM
Laying cement board oguevarra Flooring 18 12-16-2009 10:21 AM
cement board install billyg Flooring 2 07-10-2009 01:52 PM
