Thinset Adhesive - Flooring - DIY Chatroom Home Improvement Forum
Old 11-23-2009, 10:51 PM   #1
Thinset adhesive
If installing an additional layer of 3/8 plywood subfloor over 19/32" OSB do you think using a thinset between the layers would be acceptable?
dknarnd is offline   Reply With Quote
Old 11-24-2009, 12:31 AM   #2
Tileguy
JazMan's Avatar
Rewards Points: 310
NO.
That's 5/8" OSB, why is that your subfloor and what are you gonna install over the new underlayment?
Jaz
Old 11-24-2009, 05:38 AM   #3
Just bought the house, it's 10 years old. I am taking carpet up in 2 of my bedrooms and installing laminate. Reason for the additional layer of subfloor is to sturdy up the OSB some because there is a little deflection between joists in a couple of areas and I need some additional height to the floor.
Old 11-24-2009, 05:22 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 310
Since your subfloor is only 5/8", I recommend installing 1/2" underlayment grade instead of 3/8" The 1/2" will stiffen the floor a lot more than the 3/8". Underlayment should never be glued to the subfloor. If you used construction adhesive, it would actually creat voids and make the floor more spongy.
Good move to get rid of that stickin' carpet.
Jaz
White thinset and Gray Thinset, does it really make a difference.. yummy mummy Tiling, ceramics, marble 25 02-04-2012 12:00 AM
questions about thinset ponch37300 Flooring 16 03-16-2011 12:45 PM
Which type of adhesive or thinset should I be using? yummy mummy Flooring 3 01-02-2009 11:45 AM
Fortified Thinset poolecw Flooring 4 10-31-2008 08:06 AM
Thinset application question poolecw Flooring 2 10-15-2008 04:51 PM
