Thin Setunder Cement Board - Flooring - DIY Chatroom Home Improvement Forum
Old 11-03-2011, 08:09 PM   #1
thin setunder cement board
I AM CONCERNED THAT APLYING THIN SET UNDER MY CEMENT BOArD MY DOOR WILL NOT OPEN. hOW MUCH THICKER WILL IT MAKE THE TILE
TerryC.Frederic is offline   Reply With Quote
Old 11-03-2011, 08:30 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If you want the installation to fail quickly then don't use the thinset under the cement board. The thinset (under the board) represents about an elevation change of about 3/32" if applied in the correct manner. The thinset is there to 100% fill voids created when the fasteners are installed into the cement board.
Using ALL CAPS isn't necessary here, we all can hear you just fine.
Old 11-04-2011, 10:24 PM   #3
You can use a product called Ditra made by Schluter. The build up of the tile will be much less. Go to www.schluter.com for more info. I have installed several thousand sq.ft. of tile over Ditra over the last 10 years with no issues.
plowboy is offline   Reply With Quote
Cement Board Questions trophywalleye Drywall & Plaster 17 06-29-2011 10:56 PM
1/4" cement board "does not exist"! benr Tiling, ceramics, marble 5 04-08-2011 02:23 PM
Cement board meets drywall? CowboyAndy Drywall & Plaster 8 12-25-2010 08:29 PM
cement board install billyg Flooring 2 07-10-2009 12:52 PM
cement board over brick fireplace wawrow General DIY Discussions 2 11-21-2008 09:21 AM
