-   -   thin setunder cement board (http://www.diychatroom.com/f5/thin-setunder-cement-board-122312/)
TerryC.Frederic 11-03-2011 08:09 PM
I AM CONCERNED THAT APLYING THIN SET UNDER MY CEMENT BOArD MY DOOR WILL NOT OPEN. hOW MUCH THICKER WILL IT MAKE THE TILE
Bud Cline 11-03-2011 08:30 PM
If you want the installation to fail quickly then don't use the thinset under the cement board. The thinset (under the board) represents about an elevation change of about 3/32" if applied in the correct manner. The thinset is there to 100% fill voids created when the fasteners are installed into the cement board.:)
Using ALL CAPS isn't necessary here, we all can hear you just fine.:)
plowboy 11-04-2011 10:24 PM
You can use a product called Ditra made by Schluter. The build up of the tile will be much less. Go to www.schluter.com for more info. I have installed several thousand sq.ft. of tile over Ditra over the last 10 years with no issues.
