Thin Set Vs Mastic/glue For Ceramic Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 02-16-2009, 03:53 PM   #1
Thin set vs mastic/glue for ceramic tile
We are having ceramic tile installed over vinyl (on a concrete base) in our bathroom.
My flooring guy who has done a bunch of terrific jobs for us wants to use mastic instead of thin set.
My wife has this impression that thin set will be better if we ever have to replace the floor.
Also that "the tile manufacturer may recommend thin set" although we have no evidence of this.
My guy says whichever way you do it it will be a pain to remove.
I want to go with the expert who has installed hundreds of floors. Has my wife a point?
Thanks - p
ph3iron is offline   Reply With Quote
Old 02-16-2009, 04:01 PM   #2
Remodeling Contractor
Remove the vinyl tile first. Use thinset on floors not mastic.
Old 02-16-2009, 04:04 PM   #3
Floorwizard's Avatar
If your going to install over sheet Vinyl you might as well use chewing gum.
The results will be bad no matter what you do.
If you want it done according to the Tile Council of America then follow the advice that Bob just gave you.
Floorwizard is offline   Reply With Quote
Old 02-16-2009, 04:22 PM   #4
Boy - you guys are fast - thanks - p
Old 02-16-2009, 04:32 PM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 84
Never use mastic on a floor.
Old 02-16-2009, 08:57 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 346
Get a different tile guy.....Keep the wife!
Jaz
Old 02-17-2009, 07:56 AM   #7
ccarlisle's Avatar
Just so you know, 'mastic' is an organic adhesive that dries by evaporation of a solvent. Water resistance and bond strength is dependent on type and product. May require extended curing times and are not recommended for floors..." from TTMAC.
Thus the only areas where an organic adhesive may be recommended is a backsplash in say a kitchen. Nowhere else. Using thinset allows you to put down a waterproof membrane (with thinset), then set the tiles on that(with thinset) all in the same day - no waiting around for some solvent to evaporate. Get a better job with no potential for mould growth.
Number of jobs done is no substitute for jobs done right.
Oh - and really impress your wife by not allowing tiles to be placed over vinyl. You'll thank us for telling you this years from now.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 49 05-23-2013 01:04 PM
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
