Thin Set To Repair A Slate Patio? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-14-2011, 12:06 PM   #1
Rewards Points: 83
Thin Set to Repair a Slate Patio?
I need to repair a couple of square feet of a slate patio, which is Vermont slate over a concrete slab. These slates are irregularly shaped, about 5/8" thick, and two of them have become loose. However, the old cement base on which the slates sit is extremely solid. My problem is how to get the slates to stick to the old cement base without raising the height of the slates over the adjacent slates -- chiseling out the base underneath the slates is way too hard. Should I use thin set mortar, as if these were tiles? Or is there some other kind of adhesive that is very thin but will stand up to mid-Atlantic weather?
MrBill_DIY is offline   Reply With Quote
Old 08-14-2011, 12:21 PM   #2
Rewards Points: 558
try this: http://www.youtube.com/watch?v=4yRQ-...feature=fvwrel
epson is offline   Reply With Quote
Old 08-14-2011, 03:19 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 216
Honestly, I don't recommend Mr. Carter's advise for this kind of repair. You need thin set mortar.
Jaz
JazMan is online now   Reply With Quote
installing Slate title to outdoor cement Matky Flooring 53 04-05-2010 08:08 PM
slumped patio fix ?? houser Building & Construction 5 03-18-2010 07:25 AM
Replacing patio - Relocate downspout slvrbullet98 Landscaping & Lawn Care 2 05-08-2009 09:30 AM
slate patio problems jcrabtree Flooring 6 08-11-2008 06:56 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 09:11 AM
