Old 10-26-2010, 01:45 PM   #1
Question
thin set removal from hardwood floor
I am in the process of removing ceramic tiles that were installed over hardwood floors in dining room. Wood floors look pretty good and would like to refinish them after tile and thin set is removed. I am removing tiles AND thin set with different size chisels and hammer, long process! Home Depot "expert" said renting electric hammer would not work very well because of hard wood floor. Any idea of best way to remove thin set or should I continue with hand chisel?
Dhays is offline   Reply With Quote
Old 10-26-2010, 04:03 PM   #2
Tileguy
Bud Cline's Avatar
I have no good ides but someone here may. I would use a rigid putty-knife about three inches wide to scrape the floor. At some point a drum sander can be brought in but not before a lot (if not most) of the thinset has been removed.
You could also try a scrubby pad type thing with a little water but don't allow the floor to get too wet and don't let any water get into the cracks between the boards. If you do that then also use a fan to dry the floor as soon as possible.
Can I install hardwood flooring over an existing hardwood floor? Max1119 Flooring 12 05-31-2012 12:17 PM
hardwood floor to carpeted step transition DIYguy2000 Carpentry 7 11-06-2009 01:09 PM
hardwood floor removal question oscarMadison Flooring 3 05-18-2009 09:53 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 12:56 PM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 08:06 AM
