Thin Set From HD Or Lowes To Use With Kerdi - Flooring - DIY Chatroom Home Improvement Forum
Old 08-01-2009, 12:59 PM   #1
Thin set from HD or Lowes to use with Kerdi
Want to go buy any recommendations? Unmodified mortar correct? People in store look at me like an idiot
Laying over a plywood subfloor and a plywood bench.....with durarock on the walls... in the shower!
Ineedhelp2009 is offline   Reply With Quote
Old 08-01-2009, 01:15 PM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
On wood you need Modified Thinset under the Ditra. Always use Unmodified on top of Ditra. Use Unmodified under Ditra when installing on concrete.
poppameth is offline   Reply With Quote
Old 08-01-2009, 02:49 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
THOSE, are the recommendations. Not always the best advice just simply milktoast recommendations from Schluter.
Old 08-02-2009, 01:58 AM   #4
Tileguy
JazMan's Avatar
Rewards Points: 212
We're talking Kerdi here not Ditra people.
"Laying over a plywood subfloor and a plywood bench."
Subfloor, what subfloor? You don't put Kerdi on a subfloor. No plywood bench in showers either, Kerdi does not go on plywood, put Durock on the bench then Kerdi.
What going on the shower floor?
Jaz
Old 08-02-2009, 08:15 AM   #5
Jaz
Shower floor =plywood .... felt paper, mesh, mortar slope, kerdi, mortar, then tile? right/wrong?
Bench, Yes backer board, mortar, kerdi, mortar, then tile? right/wrong?
Just going to HD today, curious to what every is using from them with kerdi!
Old 08-02-2009, 08:16 AM   #6
Gotcha, same apply for the kerdi ?
Old 08-02-2009, 12:04 PM   #7
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Yes same applies for Kerdi. Go to Schluter's website. The full installation manual for the Kerdi shower system can be downloaded. You should read through it before continuing installation.
Old 08-02-2009, 01:57 PM   #8
any particular brands recommended? at hd or lowes
Old 08-02-2009, 02:50 PM   #9
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Lowes used to carry Laticrete, and now I think they carry Mapei. Both are good. I haven't been in a Home Depot in years now.
Old 08-02-2009, 03:18 PM   #10
which mapei? there is like 7 types
Old 08-02-2009, 04:11 PM   #11
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Usually we use Kerabond as our unmodified. For modified you can use Kerabond + Keralastic Additive or UltraFlex II. You could also use Ultralite for a modified product if you like. 25lbs or Ultralite does the same thing as 50lbs of UltraFlex II or Kerabond.
Old 08-02-2009, 09:49 PM   #12
they had eveyrthing but kerabond.
I seen ultra flex, but I like your idea of adding latex!
thanks for the info
Old 08-03-2009, 06:56 AM   #13
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
UltraFlex is premodified. It uses a dried polymer that it activated when you add the water. Not as good as adding a liquid additive, but UltraFlex is still a modified thinset. If you want to do it by the book and use unmodified you may have to go to a real tile store to get the correct product.
Old 08-03-2009, 09:35 PM   #14
Makes sense thanks for the input!
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 49 05-23-2013 02:04 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Don't Use Lowe's GaileDavidson Kitchen & Bath Remodeling 10 02-15-2009 07:19 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
