Thickness Of Plywood Underlayment For Tile Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-01-2011, 12:22 PM   #1
Rewards Points: 262
thickness of plywood underlayment for tile floor?
We are renovating a kitchen. We installed new laminate flooring over a "Platon" underlayment, to separate the laminate from the slab on grade. During the final stage of renovation, our plumber installed water supply pipes to the sink area - during a power outage from Hurricane Irene. when the power came back on in the middle of the night (1 AM), the well pump kicked back on, which is when I found out the plumber had left all the supply lines to the future sink OPEN! I don't know how long the "fountain" was going, but the kitchen had 1/2" of standing water on the laminate. I will be removing the laminate floor to dry the slab - due to concern for mold and ruined flooring - and may decide to put down tile instead. Question is, how thick should the plywood subfloor for tile be if put over the Platon? 1/2" or 3/4"? Thanks.
tpagel is offline   Reply With Quote
Old 09-01-2011, 12:27 PM   #2
Rewards Points: 262
Disregard post. I found the answer in a technical brochure. 7/16" minimum thickness
Old 09-02-2011, 06:53 AM   #3
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
From Platon's website:
Can be installed in conjunction with any floor covering material – carpet, vinyl, laminate or hardwood
I don't see ceramic on that list. You are about to make a huge mess for yourself. If you want ceramic, put a membrane like Ditra on the concrete and install directly on top. Platon Underlayment is not meant for this.
Darkling Designs
poppameth is offline   Reply With Quote
Old 09-02-2011, 07:09 AM   #4
Rewards Points: 262
Thanks. I went back and saw that too. We really want the platon because of the thermal break it provides. We have areas of tile directly on the slab right now and it is quite cold in the winter here in CT and probably chills the room air too. I think that little detail just swayed us back into replacing the flooded area with a higher quality laminate and taking our chances. Thanks very much for your input. Much appreciated!
Old 09-02-2011, 08:40 PM   #5
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Did you consider a vinyl tile? There are several out now that can glue down to the Platon and grout just like real tile. The tile and the grout is far more flexible than ceramic tile and cementitious grout. You can get the look and feel of ceramic without the cold feeling. Permastone has one at a good price point with a proven track record, and Shaw has just come out with a well priced one as well.
Darkling Designs
Old 09-06-2011, 11:35 AM   #6
I guess I am lucky as I was about to proceed on this idea and had layed down "Platon" with 7/16 OSB on top secured with concrete nails(fired through Ramjet) in basement kitchen and bathroom area in prepration of ceramic.
--now what do you envisage as problems / mess....?
I was a bit hesitatant after I walked on the OSB, felt a teeny bit bouncy, after reading your post I have halted the entire project.
--Would Ditra provide some insulation for cold basement floors ?
--Is laying tiles on OSb directly an option ?
I have a storm drain in kitchen area so want to address any possible overflow as well as provide some insulation in cold basements here in Toronto
looking forward to hear from all..
Thanks.
Ami
ami_troy is offline   Reply With Quote
Old 09-06-2011, 02:12 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You can not install ceramic tile over most platon floors.
DITRA will offer very little in the way of a thermal barrier.
You can never install ceramic tile directly to OSB.
How about you heat the floor ahead of the tile?
XXX
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Another thread about subflooring & underlayment choices for a first timer DIY tiler pmergler Flooring 8 07-11-2010 03:00 AM
Best adhesive for plywood to concrete floor user59291 Flooring 15 08-15-2009 07:39 AM
shed plywood floor: treated? flamtap Building & Construction 6 04-24-2009 06:05 PM
Bathroom Floor - Tile - floor Height - Flange DoItYourSelfer5 Flooring 2 12-15-2008 07:18 PM
