Old 03-05-2008, 09:03 PM   #1
fierysun's Avatar
Thermal Break For Tile
Has anyone come across an underlayment material that can be used as a thermal break between concrete and tile? I'm tired of really cold tile floors in the winter. Would a latext crack isolation membrane create noticable difference in the transfer of heat and cold from my slab to the tile?
I understand that slippers are the cheapest solution .
Trying to keep all my fingers and toes
fierysun is offline   Reply With Quote
Old 03-05-2008, 09:29 PM   #2
You could place ceramic tile on wall to wall carpet, and in the morning it will still be ice cold. Ceramic and stone feel cold because they literally suck the heat right out of your feet. It's not just cold floors or cold slabs.
LawnGuyLandSparky is offline   Reply With Quote
Old 03-06-2008, 07:22 PM   #3
Tile Contractor
Bill_Vincent's Avatar
Have you looked into electric radiant heat mats for under tile? Do a search for Nuheat and Suntouch.
"Whether you think you can, or you think you can't, You're probably right."
Bill_Vincent is offline   Reply With Quote
Just can't break sink drain free! DIYtestdummy Plumbing 6 03-05-2008 10:56 AM
Can foggy thermal windows be repaired? larry strohm General Discussion 12 08-29-2007 07:34 AM
Thermal Protectors raymer Electrical 4 10-26-2006 01:15 AM
Do I break out the flange? sharisavage Flooring 8 04-09-2006 11:32 PM
