Is There Such A Thing As A Quality Click-lock Engineered Wood Flooring? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-12-2013, 09:39 PM   #1
Is there such a thing as a quality click-lock engineered wood flooring?
Finished tiling my guest bath and laundry room, preparing to put down floors in two guest bedrooms and the master bedroom. Trying to decide between a Lowes click-lock engineered wood, at about $4.00 a square, and a Garrison Maple Natural 3/8" engineered floor that glues together, at @ $6.00 a sq. ft.
The Oak layer on the Lowes product is rotary peeled, the Garrison product is face sawn.
I plan to install floating on a vapor barrier/underlayment over flat concrete slab.
I understand that we get what we pay for...
Any opinions on Lowes click-lock flooring (or any click lock flooring)?
Any recommendations on a better click-lock product?
What are the downsides to click-lock flooring?
Any opinions on the Garrison Collection engineered floors?
Lots of questions. Thanks in advance, as always.
clambake6 is offline   Reply With Quote
Old 04-13-2013, 05:50 AM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
We've sold quite a bit of Kahrs in the past. It's one of the better ones on the market. I've more recently been selling a lot of From the Forest product and Columbia. The From the Forest has been of of the better quality products for the price.
Darkling Designs
poppameth is offline   Reply With Quote
The Following User Says Thank You to poppameth For This Useful Post:
clambake6 (04-13-2013)
Old 04-15-2013, 07:42 AM   #3
Rewards Points: 150
You might want to look at BR-111, too. Yes, there are good quality click-lock floors, but the cost is comparable to solid hardwood (if not more).
zakany is offline   Reply With Quote
The Following User Says Thank You to zakany For This Useful Post:
clambake6 (04-15-2013)
Old 04-15-2013, 11:17 AM   #4
Too Short? Cut it Again!
Take a look at engineered flooring from Duro-Design. Bamboo, for example, comes in a variety of colors and is harder than domestic hardwood. Their hardwood products come from managed forests. Great company to work with.
http://www.durodesign.com
The Following User Says Thank You to user1007 For This Useful Post:
Old 04-15-2013, 12:43 PM   #5
Rewards Points: 264
Unless you have a concrete subfloor I would consider a solid product. As you can find solid hardwood for the cost of a good engineered. If you are set on engineered 2 brands I really like that are nice and thick and have a thick wear layer are Real Wood Floors & Shamrock. Hope this helps.
Awoodfloorguy is offline   Reply With Quote
The Following User Says Thank You to Awoodfloorguy For This Useful Post:
Old 04-15-2013, 12:53 PM   #6
Yes, we are on a concrete slab.
Yes, it does help. Thanks very much.
Old 04-15-2013, 01:01 PM   #7
Rewards Points: 264
Oh ok. I would check into those 2 brands. They are both of very good quality. A couple others you might consider are; Stang-Lund, Mirage, & BR-111.
Old 04-16-2013, 07:23 AM   #8
Rewards Points: 150
What I did when I was looking at flooring was look at samples. Lots and lots of samples. Look at the wear layer. Look at the plywood beneath. If the plywood is crappy (voids, etc.) then the floor won't hold up as well. There is a lot of quality variation in engineered flooring. You might try builddirect for samples. With that experience, you should be able to find a price-quality point that suits your needs best.
clambake6 (04-16-2013)
Vapor cleaning on wood flooring? Green Cleaner Flooring 1 03-23-2011 04:55 PM
Glue down engineered wood flooring mh8888 Flooring 9 03-06-2011 06:30 PM
Another option for installing engineered wood flooring dutch Flooring 1 08-22-2010 01:28 AM
Bruce Turlington engineered wood flooring???? Oxymoron Flooring 1 01-10-2010 10:06 AM
Solidly Engineered Floors? Andy R Flooring 2 03-18-2009 05:16 PM
