Old 06-02-2012, 03:34 AM   #1
Is there mildew under the carpet?
We bought our house a couple months ago. The house is constantly smelling like mildew. Is there a way I can check without messing up the carpet? What if there is mildew under the carpet? What happens next ??
jon2ie is offline   Reply With Quote
Old 06-02-2012, 06:54 AM   #2
Super Moderator
Get down on your knees and sniff the carpet---If it smells musty--it will need removal---the musty,mildew is likely growing in the old pad under the carpet---
Old 06-02-2012, 10:22 AM   #3
Is this a crawl space or basement?
If it's a crawl space make sure there's a vaper barrier of 6 mil. plastic on the ground.
Someone needs to also be looking for any water leaks under the house.
The subfloor will be stained if there's been a leak.
Is there standing water under the house?
Old 06-02-2012, 11:09 AM   #4
Crawl space ..... There is not a vaper barrier (guess I should do that) And there is not standing water under the sub area but the ground is mosit. Thank you for your help One more question - who would I get to put a vaper barrier under the house ??
Old 06-02-2012, 06:52 PM   #5
Super Moderator
A basement waterproofing company will provide that service---
Old 06-02-2012, 07:13 PM   #6
It's a super simple job, why not do it yourself and save a ton of money?
The Following 2 Users Say Thank You to joecaption For This Useful Post:
jon2ie (06-04-2012), oh'mike (06-02-2012)
Carpet Flooding and Replacement airjay81 Flooring 1 05-08-2012 01:00 PM
Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr chetsy Off Topic 9 12-03-2008 07:41 AM
Help!!! Mildew in carpet parsono10 General Discussion 2 11-28-2008 10:15 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
