Old 11-27-2013, 11:59 PM   #1
is there a graceful way to change orientation of laminate floor
I am installing laminated floor perpendicular to the opening of the closet opening. The closet opening is 6 feet wide. But inside the closet, I wanted the laminate plank to go parallel to the opening. Is there an easy way to do this. Can you cut the pieces and glue it back
alsoufo is offline   Reply With Quote
Old 11-28-2013, 01:13 AM   #2
Rewards Points: 3,348
Only way to do it is with a transition Tee strip.
http://www.bing.com/images/search?q=...ectedIndex=162
How to keep tile floor level with laminate? farang Flooring 9 08-25-2012 05:35 PM
Laminate floor in basement questions ryoung25 Flooring 8 09-15-2010 10:33 PM
Problem with stain on Laminate Floor Lilypebbles Flooring 4 11-04-2009 04:06 PM
laminate floating floor squeeky, is it normal? gagaliya Flooring 1 10-02-2009 05:27 AM
Installing Laminate over uneven pine plank floor? tomzpc Flooring 6 04-16-2008 08:07 AM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
