Texturing Over Wallpaper - Flooring - DIY Chatroom Home Improvement Forum
Old 07-28-2010, 10:30 AM   #1
texturing over wallpaper
Hi all I am new on this forum.
Has anyone ever textured over wallpaper. The wallpaper is in our bathroom and has been on for 13 years and is still solid....not lifting anywhere. 10 ft ceilings in bathroom so bath doesn't really get steamy. Approx 9x12. We've been told if we use an oil base primer that it should be fine. Just wondering if anyone has had experience with this?
Thank you!
P.A. is offline   Reply With Quote
Old 07-28-2010, 10:44 AM   #2
Rewards Points: 558
Before you try texturing your wall make sure you use an oil base primer to seal the wallpaper, this should keep the moisture out. But nothing is fool proof and you might still get bubbles and to fix that problem you would have to cut out the bubbles and repair the problem.
My advice, I would remove the wallpaper fix and patch any cracks and then apply a good oil primer to the wall and then put your textured finish onů
epson is offline   Reply With Quote
Can I paint over wallpaper primer? CLM Painting 3 07-15-2009 03:40 AM
Removing Wallpaper fcamargo6thave Painting 17 04-27-2009 02:59 AM
How many layers of wallpaper is too many? dumbunusedid Painting 14 07-19-2008 04:48 AM
This wallpaper glue is stubborn! proofer Painting 7 03-07-2008 05:53 PM
wallpaper on untreated drywall... rjralston Remodeling 4 09-09-2006 12:13 AM
