Temporary Subfloor Coating - Flooring - DIY Chatroom Home Improvement Forum
Old 02-28-2012, 10:18 AM   #1
Rewards Points: 201
Temporary subfloor coating
I am building my retirement house on a shoestring, so to speak.
The outside is finished; starting to work on the inside now.
The subfloor is 3/4" T&G Advantech. I would like to move in before
putting down flooring as I don't quite have the funds for the flooring just yet.
(hard to save on soc. sec.)
I would like to coat the subfloor with something relatively cheap (paint, polyurthane, etc. ?) so as to make sweeping easier and prevent wear until I can afford to put down flooring.
Any suggestions on what to use ?
Arky
Arky217 is offline   Reply With Quote
Old 02-28-2012, 10:28 AM   #2
Rewards Points: 13,976
A lot depends on what you plan on for a finished floor.
I do not feel Paint over Advantic is a great idea. By design it's made to repel moisture it's not likly to stay stuck down.
Some cheap laminite on sale can be bought for about $1.00 a sq. ft. and would hold up far better and be easy to install and remove.
Old 02-28-2012, 10:46 AM   #3
Rewards Points: 201
Thanks Joe,
I haven't decided on the finished flooring just yet.
Maybe rolled vinyl, at least in kitchen and bath.
And possibly laminate elsewhere, but definitely not carpet anywhere.
But for now, even at $1/sq. ft. (1200s.f.=$1200+tax), thats more than I can spend just now,
(so many other things to buy to get it ready to move in)
and I especially don't want to spend that much for something that's just temporary.
Maybe just some kind of cheap sealer that will make sweeping a bit easier and keep the dust down.
Arky
Old 02-28-2012, 10:54 AM   #4
And how do you plan on attaching vinyl? You would have to go over the Advantic with 1/4 Sanded plywood to get it to stick. Advantic is not rated for underlament for linolium.
And any glueless linolium would cost far more then reguler linolium, and more then laminite.
Old 02-28-2012, 11:01 AM   #5
This may help with your decision.
http://www.advantechperforms.com/tec...tion/faqs.aspx
If vinyl planks are a temporary flooring how temporary? mommiemara Flooring 0 09-14-2011 10:14 AM
Help with Temporary Support Needed DIYerIT Carpentry 3 05-12-2011 01:46 PM
Temporary support ideas for temporary beams? WillK Building & Construction 10 03-18-2011 08:37 PM
Temporary suport in old house Cossack Remodeling 4 04-04-2010 08:16 PM
Temporary wall support question discojv Building & Construction 7 01-25-2009 07:23 PM
