Old 01-31-2013, 10:04 PM   #16
Temporary flooring install
you either have to use durerock or hardi-backer mortared down so the floor will not flex and the grout break
christy74 is offline   Reply With Quote
Old 01-31-2013, 10:24 PM   #17
JetSwet's Avatar
Backer board and or durock will not prevent the floor from flexing, its just a tile bond.
JetSwet is offline   Reply With Quote
Old 01-31-2013, 10:35 PM   #18
not wanting to argue but if the backer board is mortard down and the total of sub-floors are going to be over a inch thick it will not flex
Old 01-31-2013, 10:48 PM   #19
JetSwet's Avatar
It wont flex because of the plywood if put down correctly. Cbu is just a filler to hold tye tile down.
Old 01-31-2013, 10:56 PM   #20
okay have ever took up tile with cbu morterd down
Old 01-31-2013, 11:15 PM   #21
cbu adds no structural strength to a floor.
Old 01-31-2013, 11:24 PM   #22
yes i understand this it all comes down to the underlayment but i have laid thousands of feet and if what you call cbu is put down right i have never had any problems
Old 02-02-2013, 07:10 AM   #23
JetSwet's Avatar
Huh?.....
Old 02-02-2013, 11:01 AM   #24
I was planning on trying my hand with ditra.
MissKat is offline   Reply With Quote
Old 02-03-2013, 08:05 AM   #25
Super Moderator
Just a word to our members when trying to help people who are doing a task for the first time--
AVOID abreviations---CBU ? OSB? MDF?
This can be frustrating and send a new member elsware for clear understandable directions---
Every trade has this problem---not bawling you out here--just reminding you that CBU might not be good to use if you have no idea what it means.
Hardwood Flooring install around this trim? Cmudr1 Flooring 4 01-31-2013 11:29 PM
Crazy?....but how do I install hardwood flooring on wall yummy mummy Flooring 37 01-08-2009 06:19 PM
Can I install Lam Flooring without clearing room? gmhut Flooring 2 08-21-2008 10:23 AM
Peninsula install on Laminate flooring? mcaanda Building & Construction 1 05-22-2008 01:01 AM
