Temperature For Installing Plank Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 03-08-2012, 11:00 AM   #1
temperature for installing plank flooring
1. can installation of pine plank flooring be done in below freezing temps or should I wait until it gets warmer? (finishing/painting to be done when warmer).
2. if installing on wood floor joists (25 inch span), is it necessary to have a sub-floor?
3. is it necessary to have a moisture barrier if there is no sub-floor and if there is a 2 inch air space between the plank-flooring and insulation?
4. is a moisture barrier needed on second-floor plank flooring (joist span 20 inches) if insulated 20-25inches along the perimeter wall where the cold can creep in?
thanks
mattgraz is offline   Reply With Quote
Old 03-08-2012, 02:25 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Planking should be acclimated to room temp; joists are spaced too far apart. 16" max.
How thick is the planking?
titanoman is offline   Reply With Quote
Old 03-11-2012, 01:04 PM   #3
Thanks for the reply. We are dealing in centimeters since I'm in Europe. Floor joists are 50cm centers and planks are 3cm thick tongue and groove, 10cm wide. Temp inside house and out is the same since it is not yet insulated.
Old 03-11-2012, 01:28 PM   #4
Rewards Points: 13,270
Unless you want cold air and rising moisture to come up between the flooring your install then install Advantec subflooring.
Is this T & G plank flooring?
Plank flooring for new construction DidjaDewit Flooring 3 10-17-2012 05:56 PM
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 08:42 PM
?laminate or allure vinyl plank flooring? suevwbug Flooring 0 05-09-2011 10:26 PM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
New Hardwood over Plank Flooring christianjl Flooring 1 08-24-2009 06:51 AM
